2nd Gen Rear ABS Light
chester4Run
There's some misinformation on this issue around, and I finally figured it out, so I thought I'd post. Background: I've had the yellow Rear ABS dash light lit since my son did an emergency breaking maneuver as part of an accident he was involved in. I couldn't find a problem with the rear brakes nor the sensor in the differential. But I also couldn't seem to disable that light.
These posts helped me find the solution:
Can I disable/remove my 2nd gen rear ABS? | Pirate 4x4
ABS Removal
removing rear abs - YotaTech Forums
The solution is to unplug BOTH the ABS computer and the ABS relay.
The ABS computer is behind the glove compartment, up behind the horizontal metal bar. You'll need to remove two screws and a nut then pry/wiggle it downward, then you can unplug it. The plug release is on the top of the connector, which isn't accessible with it installed.
The ABS relay is fastened the passenger side of the engine compartment near the hood hinge with a single bolt. Unplug it.
I also removed the EFI fuse for a few minutes for good measure, but no ABS light on the dash now (doesn't even test light when the key is turned). I removed both components and electrical taped the plugs.
I have a 1993 4runner 2wd, I recently unplugged my ABS computer and relay, plus I disconnected the rear speed sensor and the ABS modulator. The ABS light does not turn on and the car is braking well. However, my radio doesn't turn on anymore. I wonder if it's related to me disconnecting the battery, all the fuses look normal.
Not sure what was the issue with the aftermarket radio. But I ended up connecting and disconnecting the factory AND now the aftermarket radio works. As far as the ABS, I need to figure out how to remove the ABS actuator/modulator (?) since it continues to leak powersteering fluid. Gonna look for a non-ABS truck at the junkyard and replace the hoses.
tuṣṭāva
