2nd Gen steering wheel control button pics needed
Deuxdiesel
I've been refurbishing my '95 for two years now, and it is finally back on the road. One problem is the steering wheel buttons are completely void of any markings, and since I have no owners manual, I don't know which ones do what. I still need to get the cruise working, so any pics that show the lettering would be helpful.
Thanks in advance.
I was trying to figure mine out on my way back from where I bought it. I'm pretty sure my cruise does not work because I pushed each button individual and had no luck holding a speed.
Buttons from left to right
Now dont quote me on this but the first button not really sure what it does from left to right remember but the second button does say cancel on my 94 not sure if the buttons are the same or not but maybe they are the third button has a plus and minus setting for it now I have two theories but because I don't currently have a stereo it could be for volume or be adjusting cruise control if that is the case the first one is most likely cruise control.
No stereo controls.
Left side is your on/off button for the cruise. If your cruise will work, at least with the electrical, you should see a green indicator on your dash when you push this. The right side buttons: small round one is 'cancel' and larger one is 'resume/accel' on the top and 'set/coast' on the bottom. My '92 had a bad set button that would stick because it was missing the spring or broken or something. I perfected pushing set, and then pushing slightly on resume to get it to work.
Other thing to remember is that if you are used to cruise on newer vehicles, my experience with mine was that there was a little bit of a lag between setting the speed and having it take over and holding. So if yours actually works, be patient with it to test it out. Push the set, then take your foot off the gas, and then it will pick up a half second later.
