3.0 injector connector
bootheel
Haven't found the answer I'm looking for through searching, so figured I would throw it out here and see what turns up. I have a 94 SR5 with a 3.0 that has a mouse nest in it between the upper and lower plenum. Found this out while pulling the upper plenum to replace valve cover gaskets. No idea how long they have been there, but they have chewed into three of the injector connectors which could explain rough idle and general sluggish performance. Is there a replacement for these that can be spliced into the harness? Didn't see any listed on camelback, but did see some densos on eBay but wasn't sure which would be the correct ones for this engine. Does anyone have any insight on this that can point me in the right direction?
are you still needing to find fuel injector replacement plug? If so, then I may be able to look up the part number for a replacement plug-
I appreciate the reply friend. I actually forgot about posting this. I ended up buying a new set of injectors that had a different male connection, but came with an adapter plug that had oem connector on one end and new style on the other. Then, I cut the oem plug off of one end so that left me with a pigtail and new style connector. After that I trimmed my wiring back so that the damaged wires were removed and spliced and soldered in the pigtail to repair the harness.
D'Angelo
