3.4 02 auto to 97 5speed swap Pinout
603Mission
Hey guys haven't seen much in depth threads to do ECM pin out between an 02 Auto and a 97 Manual. So i figured I'd make a thread to post in for suggestions and just for people to check out. First major thing i've come across while looking over the diagram, when looking at the camshaft sensor pins i noticed on the 02 C1 was spliced over and i'm not to sure what to make of this. I've attached pictures of the wiring section that's got me confused.
Id also like to give a SO to [MENTION=10169]TheDurk[/MENTION] for hooking me up with the files so i can get my charts filled out fully
your trying to swap 97 manual transmission into a 02. Because few weeks ago there was a thread about this. Someone swapped a manual transmission into a 02 using a 04 tacoma ecu. Just need to search and do research. It’s been talked about!
And ya know i looked back and decided its probably best to just get the ECU for a smoother swap now i just gotta wait for the snow to melt so i can get the donor out of its spot!
Will post pic of the swap
Haven't seen much, 'cause it's not really possible. That is, without changing engine parts and wiring.
Due to the wanna-be Drive-By-Wire throttle body on the '01/02, the '00 and older won't properly run your engine.
Options are-
1. Use your ECU and have a CEL.
2. Get an '03/04 manual 4WD Tacoma ECU.
