Body plug pinouts?
vegask
Member
So I have been searching on and off for weeks, I was wondering if anyone had a pin out for any of the 3 body harness connectors on a 96-99 V6 Auto?
Getting ready to do a v8 swap, I have all the wires figured out on the new motor and ECM, its the chasis side of my 4runner that remains a mystery.
You'll want to narrow your search down to 96-98. Big changes in '99 from the earlier years.
A TIS 2-day subscription is pretty cheap and you can get all the diagrams you need. Once you figure out the name of each of those connectors, you can piece together the information you need. Toyota doesn't generally list out harness connectors with wire descriptions like the image you have above - you basically have to do it yourself.
-Charlie
-Charlie
I got the TIS and started downloading. Found out last night I can actually search those PDFs for "II2" and "II3" so I am slowly piecing them together. Looks like what I posted for the II3 connector is for a manual which appears to be a lot different.
Bingo. In each subsection that uses a harness connector, it should be listed with the pins used in that section, the non-shown pins and empty pins - which will help you get things figured out.
I've done this on a few Toyota motor swaps through the years... It takes a while, but the diagrams are good once you get the hang of it. Mark every wire before you cut...
I had long contemplated a 2UZ swap, but since Magnuson came out with updated supercharger design, I decided to stick with the 5VZ.
One minor hint/idea - get a Hilux Surf Diesel radiator - the inlet/outlet are in better positions for the V8.
-Charlie
erinobr2000
