3" Lift Kit, Best bang for my buck
Once all material for lift is purchased, can you take it to a local shop to have installed? Do i need anything special to do it myself?
Yeah you can take it to a shop to get it installed but unless you're half witted please don't. You'll save yourself a shitload of money doing it yourself. I did mine with the help of a high school buddy mostly going off write ups on here. The only thing you'll probly have to get done by a shop is the strut assembly. If that doesnt make sense let me know but the two times I've had to get struts assembled I just took them to a mom and pop shop and they did it in like 30 minutes for $20.
if you've got a jack, jack stands, socket set, breaker bar, and a bit of patience you should be able to do it in your moms garage. If you get the rear shocks with the springs that'll be a PITA but strength through peril my friend
any shop you go to is going to charge you more than the price of parts to instal it
you said tacome but what abput the tundrastruts is it the same
Pretty sure the tundra shock is different and will not work, the only reason the taco shocks work is because the tacoma and the 4runner are built on the same core components if that makes sense.
[MENTION=82211]TCMach[/MENTION] help me out here brother
00-06 Tundra TRD coils and shocks will work for our trucks. I used to run these springs on Tundra Bilstein 5100 shocks.
The difference between the two is the top hat size. The tundra coils have a larger inner spring diameter thus the top hat is bigger. I learned this when i tried to swap my Toytec/Eibach 112620s which are tacoma coils on (smaller inner spring diameter) and had to buy new top hats. However, both top hats will bolt right up to the 4runner mounts.
If your looking to go on the cheap I'm assuming your trying to find a full strut assembly off of a tundra? This would net you probably 2" of lift.
Hi I'm looking at a suspension factory replacement or a slightly higher version like the one you mentioned for 610,. I was wondering where the best place to get these kits are,. I do not want to buy something twice,. any feedback would be great,.. I just picked up a 1997 sr5 5spd etc,.
I have a 2000 toyota 4runner limited that I would like to do some stuff to but I know nothing about cars. I want to put 32 inch tires on it and put some new rims on it. I plan on taking this off road typically on trails and some mud holes, just average stuff nothing crazy. I need some help figuring out what to buy though, I dont know what I need to do in order to be able to fit these tires and I dont know what products to buy or if I have to install all of this by myself or if a mechanic can do this for me. Please reply, anything helps!!!
TRD Tundra coils: $60 (Craigslist)
Coil Isolators: $22 (Wheelers)
OME 890: $120 (Classifieds)
Tundra 5100's: $360 (Down South Motors) [set on first perch]
3/4" bushings: $10 (Amazon)
Panhard Bar Drop: $Free
Diff Drop: $30 (Toytec) Haven't needed it.
Total: $572. I was pretty happy with it, and the ride is great! Definitely better than stock, and is what I would call planted. Especially with a little weight in the back end!
Hey guys so i have been looking at the fj80 rear structs and toyota tundra struts for the front. I'm new to all of this and not sure if I have it all correct. Can someone take a look at the links and see if im good with buying these?
Toyota Tundra 2000-2006 Brand New Direct Fit PAIR of Front Struts With Springs
Toyota Tundra 2000 2006 Brand New Direct Fit Pair of Front Struts with Springs | eBay
2 Rear 50mm Lift Coil Spring Landcruiser 80 Series FJ80 FZJ80 HDJ80 HZJ80 1991-98 Toyota Wagon Pair
Pair Rear HD 50mm Lift Coil Springs Landcruiser FJ80 FZJ80 HDJ80 HZJ80 1991 1998 | eBay
Rear Gas Shock Absorbers Toyota Landcruiser FJ80 FZJ80
Rear Gas Shock Absorbers Toyota Landcruiser FJ80 FZJ80 | eBay
http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.html
this link also has the part # for each piece, you can see if eBay has the best prices or not
LC coils are the front coils off of an 80 series landcruiser that you can use on a 3rd gen to lift the rear end up.
Sorry im new to this form, but I recently bought a 96 4runner and want to lift it, but hear a lot about the panhard drop problem. As to witch side to put it on, the axel or frame side, a lot of people say dont do it on the frame side. Also i cant seem to find any LC coils around, does anyone know where i could find some? Or anyone have some they could sell me? Any info will help. Thanks - Adam
I'm stoked, my SS 1.2 kit should be here next week. Already have everything else, should be lifted by mid June. Just in time for a camping trip to trinity Lake for some fun in the sun and red dirt.
Oh yeah, my cost:
Tundra Strut Assemblies: $347.00 (parts were cheap, $80.00/side, but shipping to Canada killed me)
LC 8 wrap Coils: FREE (should be able to get some used for around $100.00 pair)
Rear shocks: $110.00 pair (Skyjacker 2.5" lift shocks)
Diff Drop: hard to tell, got it with my previous lift, but Diff drop kit from Toytec retails for $29.99
Toytec 3/4" Top Plate spacer. $60.00
All in all, my cost: $546.99 (including shipping to Canada)
Should cost you: $460.99 (plus shipping)
Hi guys, this is probably a silly question but why do you guys talk about buying shocks after you mention that you bought LC shocks...?
Sent from my EVA-L19 using Tapatalk
He is doing tundra front struts. The land cruiser shocks are to match the rear 7 wraps or supertech coils.
I would say going the Tundra/LC route is the cheapest for a good ride. The setup that is sitting in my garage cost me $450.
Tundra Coils/shocks- $155 Car-parts.com
1/2 Toytec Spacer- $40 T4R member
7.5 Wrap LC Coils- $65 Yotatech Member
LC Shocks (haven't bought yet) ~ $70 Dealership
Diff Drop- $30 Toytec
Toytec 1" Body Lift- $100 T4R member
If you want all new go with Toytec Ultimate or Sonoran Steel 1.2
Hi I am new to this I just picked up an 02runner with 98k, All I want is 2 or 2.5inches of lift or so and I keep hearing about LC coils and how they are they way to go. Where I get confused is how so are bad and some are good, would you happen to know a list of part numbers for me to track down to get the amount of lift needed
You dont want LC coils then. They'll give you anywhere from 4-6" of lift in the rear. OME 890's will give you about 3" in the rear & then maybe TRD Tundra coils w/ Bilsteins in the front on the lowest perch for 2-2.5".
Keep researching, there's tons of lift threads.
Go here. Huge help for me. http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.html#post567802
I agree with Scramble, above. Sounds like the Tundra coil lift would work well for you.
Does it matter what year for the Tundra Coils and Struts? I am looking to do the Tundra front and FJ80 Rear Spring set up and I have a line to get 2000 Tundra front suspension?
Thank you in advance for your answers!
