305/65R18 anyone running these?
FourEyedWilly
Have a chance to pick up a set of five including rims cheap. Looks like a 33.6 inch diameter. My first instinct is these will not fit on a Daystar lift with rim spacers, but can I get a quick confirmation? If they do, I will go pick them up today.
With only a daystar lift.. no way. Your too wide & tall. Stock wheels? Trying to fit these you will need to chop ... a lot .. probably even a body mount chop.
Issue, the tires are too wide. So you put on spacer, but that changes the wheel turning radius which forces you to trim and lose your mudflaps. But these are so big that you'll probably need more like a 4" lift, that is not possible to do with a spacer lift. So your looking at coilovers with aftermarket UCA's, and a new rear setup. In essence to fit you are much better off just getting smaller tires it will be cheaper, your loosing the cheap tire value when you have to buy so much more to make them work.
Thanks Pete! I thought so from what I could find searching. They do come with new rims and in the not so distant future I am going with the Overland Warehouse lift, but I still didn't want to go more than a 32 inch tire. Oh well next time. Thanks again.
TerryNap61
