30k service.....What do you guys think?
Rez90
I called toyota to see what the 30k service entails. Aside from the basic oil change, tire rotation, air filter they do the spark plug and the diff fluids...
For $900!
are you kidding me?
I'm having new tires put on in 2 weeks and i asked them about the service. They told me the diff fluids were a good idea along with the oil change but plugs shouldn't need to be done at 35k...
what do you guys think?
Never ask a dealer for the "x,000 mile service". You'll get a high price on a package containing a lot of stuff you don't need.
Consult the Maintenance Guide and get service department(s) to quote for the specific things that it says need to be done at that interval.
For $900!
are you kidding me?
Buy your own Mobil 1 or other oil/gear oil. Your local Speedee will do it all for about $100.00. Have Toyota tighten and inspect and change the plugs air filter and cabin air filter if they need it. Probably around $200.00 go through the list service by service. 900 is sillymoney.
I priced out 60K service at my dealer and was quoted about $500. I asked for a printout of the services that were included, that list included a LOT of "inspect" tasks, not a lot of "replace" tasks. I could not believe they wanted that much money for that little amount of work.
$900 is absurd.
I am in Norcal and about to get my 30k Service done at Capitol Toyota. Got Quoted $388+taxes on parts for all 30k items including Spark plugs + Coolant change. They are also running a special this month. if you bring your car during the weekdays after 4pm, you get an additional 20% off. with that discount, it will come out to around $340 out the door.
I called toyota to see what the 30k service entails. Aside from the basic oil change, tire rotation, air filter they do the spark plug and the diff fluids...For $900!..........what do you guys think?
I think if you are somewhat handy and not afraid to get a little dirty.....do it all yourself! Rotating tires is simple, you'll just need jack stands.....the spark plugs, diff/transfer case fluids and engine oil can ALL be accomplished with simple tools. (you will want a small pump to "pump" the fluid into your front and rear diff as well as your tc.......about $5 at auto part store). All of these tasks have a "sticky" here.
A big plus: knowing you did it yourself gives one a great feeling of satisfaction (and knowing you save a ton of coin).
IF you are NOT handy and/or do not have time, take it to a trusted independant shop. Doing this SHOULD cost less than the dealer.
