315/70/17
Big D's 4Runner
How much lift and what kind of things will i have to do to my 96 4wheel drive limited to make them work. I can buy a brand new set of BFGs for 400 bucks. I know i have to buy wheels but im sure ill have to cut and trim things. A list of things would be great. Thanks guys in advance.
I did a toytec 3.5" lift and 1.5" BL. I haven't trimmed anything but I put a ODL bumper on mine. I'm running what equates to a 34ish. See my build thread.
It rubs when its stuffed for sure, so you'll need to beat in the pinch weld.
You will need spacers if your using stock rims.
I wouldn't run more than a 33 without upgraded brakes. You can get by without it, but you will be saying woulda coulda shoulda when you rear end somebody because you cant stop. If you have a deer killer out front like I do, prepare to deal with totaling the guys vehicle in front of you. Plate steel and recovery points are unforgiving upon impact to civilian vehicles.
I'm running 315-70-16's...I have a Toytek 3" lift with stock wheels on a 2000 SR5 with Limitied fender flares. I did have to do the pich weld mod. I also have Spyder Trak 1.25 wheel spacers...don't know if I have to have them, I just like the wider stance.
I have no rub issues driving around town; however, I believe I would have some problems if I went off road. I think if I went off roading...I would need a 1" or 2" body lift.
Good luck...
I have the ome 3" with a 2" body lift and i trimmed some of my fender in the front and only rubs when hitting a very hard bump. i also rub on the limited mud flaps in the rear when flexed
Thanks for the input. I really want to stay away from a body lift if possible. If i do it ill go with some mickey Thompson wheels that i found i like. Im assuming the tundra brake upgrade will be plenty? Not planning on much off roading mainly just for looks.
I understand you're new and all but please use the search feature as well as refer to the Sticky's. That's what they are there for. This topic has been discussed many many times.
