33's and stock brakes
KidVermicious
I'm looking to get opinions specifically from folks that have run 33-ish tires with the stock brakes. Obviously better brakes would be optimal for oversize tires, and it'll happen eventually, but should I wait until I've upgraded to put the 33s on? Or will the stock brakes be useable while I save up for the next stage?
You should be fine with the stock brakes, Kid--I've been running 35's with no problems. I'm considering upgrading to discs in the rear eventually, but the factory system is quite capable as is.
Agreed! I have stock brakes as well with my 35's. Just make sure they're in good shape.
Your stock breaks are fine. Aluminum wheels will help, they have less rolling resistance than a steel wheel.
And Bucknut, you dont have the same breaks as Kid does. I believe the upgrades hes talking about would be putting v6 calipers with the dual diaphragm booster and 1" MC out of a 2nd gen 4runner or 3rd gen pickup. amirite?
I think tundra breaks also bolt on, but I dont know what for sure.
But I've got less truck than he does, too. :lmao:
Yup - v6 calipers and a 1" MC, and mustang calipers on montero rotors in back, ss brake lines all around. With 4 calipers I don't think I'll need the dual diaphram booster, we'll see!
FWIW: I have the stock 4 cyl brake setup, drums in the rear and I used steel wheels and aluminum and had zero issues with braking. My 4runner stops just fine with excellent braking power.
Well im running 1 ton calipers in the front and 3/4 ton calipers in the rear with a 1-5/16" MC with a dual diaphram and a vacuum canister. I can lock up 40's just fine.
ohh... and I know you secretly envy me and my incredibly small penis.
Oh and i prefer roller skate over stilts...
DSC00969.jpg~original
What'd you do, Nate--keep adding Miracle Grow to a childhood roller skate and one day this beast appeared in your garage?
AHAHAHAHA!!!
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/ZB_xQ3XcvVg?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZB_xQ3XcvVg?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Aww, nobody hates you, Nate, we're just laughing at your series of busted bell-housings and getting our digs in while we can. We'll all be suitably jealous once your girl is rolling again and running over our trucks like they were speedbumps. :driving:
DexterShaYang
