35's with a 3" lift?
cypherzion751
I know that it is a typical noob mistake to write a "how much lift to fit xx sized tires" thread, but I couldn't find any info on it. I am going to be getting a 96-98 4runner this summer and I was planning on getting the toytec 3" ultimate lift kit (with HD coils since I am going to be running a arb front w/winch and cbi rear with tire carrier) but I wasn't sure if a 3" lift would be good enough to fit 35's. I like to keep my rigs fairly low with big tires, but I don't want to do this to the point where the suspension isn't usable. I was also toying with the idea of getting a slightly wider stance and avoiding too much tire rub by getting a different backspaced wheel, but I don't know what the standard bs is and what I would need. I don't mind getting out the bfh and cutting out/reshaping the wheel well if necessary (but would be nice to keep it to a minimum). thanks for the help :)
Not going to happen! Unless you want to do a lot of cutting and tubing.
Those who run 33"s have rubbing and need to do a little pounding and cutting. Most add a small body lift too.
You will also need to do a gear change too.
Could I get away with a 3" lift and 34's as long as I got spacers? I don't mind getting out the bfh....lol.....if not I'm ok with 33's but what amount of lift should I be looking at for them? I'm sorry about all the questions lol...it's just that I don't want there to be a huge amount of extra space in the wheel well lol. I just want to keep it fairly low without compromising flex and the biggest tires I can fit without losing functionality. I'm not afraid to pound out parts of the wheel well if I have to
Space allows room for flex.
My front has over 9" of actual wheel travel. (~3" of droop and 6" of compression)
My rear has over 10" of actual wheel travel (~4" of droop and 6" of compression)
I have a 3"+ lift front and rear and my 32"s rub in front on the top of the inner fender liner, the rears are ~1/2 from the inner wheel well.
This is why most people run a 1"-1.5" BL with their 33"s.
Wheels/spacers/backspacing. The less BS (further out) the larger the acr the front wheels will take when turning. This will cause more rubbing on the rear of the wheel wells/firewall.
I had zero rubbing there until I added 1.25" wheel spacers.
Thanks, that clears up alot. I guess I have been thinking in terms of coilovers and not Ifs/coils.... I'll probably go 32's and a 3" lift since I don't like the idea of a body lift :)
Here's a link to show what someone else did.
35's on a 3rd gen 4runner
**edit Wasn't there an article of how to fit 35s on stock suspension? It was a good deal of work but it can be done if I remember that article correctly.
This is Tundra TRD front coils (~2.25") and OME 891 rear (~3"). Tires are BFG AT 265?70-16 (30.7")
P5120026.jpg~original
This is ToyTec Coilovers (~3.25") and LC 9.25 wrap (~ 5"). Tires are Yokohama AT/S 265/71-16 (31.9")
LC925lift.jpg~original
dude even if you get it to not rub in the city with 35"s, won't it rub badly whenever you try to flex the suspension while offroad?
Yeah, even with a 3" susp. and a 2" body, you really need to tub the fenders for it to be functional off road. However, if you're gonna hack into the fenders and firewall, you could always just hack a little more like the Trails Less Traveled - 1996 4Runner (the one I think cj80cruiser was referring to) and then you don't need the body lift.
I'm running 295/70/17's with 3.5" lift in front and 4" in the rear, i rub BADLY in the rear any time i off road, and that is barely flexing, i would recommend 285's if your just doing a 3" lift, ill defiantly go smaller on my tires next time or ill add a 1.5-2" BL
:lol: my grammar is terrible; no more android posts.
Anyways, this is why I have ran with 275x70xR16 to date and will probably go no higher than 276x75xR16. I have 2.5" front and 3.5" rear and I still get really really close to rubbing on the trails.
I have a 99 with a OME 3'' suspension lift, Toytec 2'' body lift, and 1'' wheel spacers and still rub at full turn. I'm running 35x12.5x15 Cooper sst's. I don't see how you could get 35's on with just a suspension lift.
This thread is from 2011. Guessing he figured out by now. Damn spam account reviving threads.
Okay so I know this thread is a few years old but it seems like a good place to share this. I realize most of the guys on this forum have 4WD 4Runners which after looking at everyone's responses require a body/suspension lift for 35s. However for the few people like me who run 2WD models I think I have an option that doesn't require a body lift. My 3rd gen has a Solo Motorsports Mid-Travel front end which contains a 3 inch lift spindle and adjustable coilovers. I only have 33s and so I actually lowered the coilovers and the front is still slightly higher than the rear which has a Rough Country Lift Spring. Whenever I have time I have a friend with 35x10.5 inch baja tires that I think will be perfect for 2WD guys. If anyone has any tips and suggestions please chime in. Thanks.
I think 32-33's with lift is a good compromise of flex and looks. From what I have read elsewhere, spacers will only make you rub more.
35's are probably not gonna happen without a lot of headache. Your best bet is to either do the lift and go with 33s or do a 2 inch body lift.
I currently have around 3.25 inches in the front and almost 5 inches in the rear. I clear my 33.5 inch 255/85R16 tires fine but I do rub the front when flexed and turning hard. A 1.5 - 2 inch body lift would let me clear 35s though.
Here's the tread on my lift to see what it looks like: Tundra/LC Lift + First Time Off Roading
premiumusedautoparts
