3rd Gen 4Runner Buyer's Guide
Lots of great info there. Wish I would’ve read it before buying my first 4runner! (Sorry for the dumb post, trying to get my post count up)
I feel like I've been posting in this thread way too much, as I've been looking for a Runner for almost a year at this point, but I figure the worst than can happen is that I get ignored. Anyway....
I was wondering what the consensus was on these two trucks:
https://washingtondc.craigslist.org/nva/ctd/d/2001-toyota-4runner-sr5-118k/6748901173.html
https://baltimore.craigslist.org/cto/d/2002-toyota-4runner-4x4/6746224999.html
Both seem way undervalued for the mileage and condition. I would imagine the dealership would have good reason to price them low. I called both numbers, no response yet. Anything I should be on the look out in particular that would cause them to price them so low?
Just purchased a '00 Limited with 4-speed auto trans. Doesn't look like the transmission ever had a service. I'm at 146,000 miles. A good mechanic in my area said it's probably not a good idea to do a fluid swap if it hasn't been done at this point because it could agitate the transmission and start causing problems. Anyone have additional input on this?
Following this because I’m at the same point. 144K and novtrans ever been messed with.
Still have to fix that slow leak in an engine gasket. But runs like a top.
I did run my Mazda move to 198K wo ever doing a trans fluid swap/clean. Never had an issue.
Carry on.
Lots of great info on my new to me 3rd gen 4runner. Is it just my computer or are a lot of the links (owners manual, shop manual ) no longer avail?
Yes, there are many dead links. But my level of care is quite low.
Well I still appreciate all the work you put into it in the past! Lots of great stuff! And your Taco is sick!! I have an 11 Taco that I just finished the 2012 front end swap on also. Hoping to make my 3rd gen 4runner very similar to your first one.
Awesome resource! I'm starting to look for mine. Thanks for all the work.
What do people think about a 'new' engine or transmission? Seen those pop up a few times. Would normally be a red flag for me but never really shopped around for 200k+ vehicles.
I have an '00 Limited, but it has a scoop hood. Was there any factory package that included this combo?
Not sure I'm the most qualified to answer, but from what I've read it wasn't an option. A lot of people liked the look though and installed sport hoods themselves. The hood should have a VIN someone where on it so you can confirm either way. Not sure where it is though.
I see that the OP isn't maintaining this Guide regularly any more but I'd like to pose a suggestion regardless.
I think a problem under the "KNOWN ISSUES & RED FLAGS" section is in order to warn about the ABS Power Brake Pump Master Cylinder Booster Assembly leak/failure issue and the approximate cost of the repair, common in the 2000-2002 T4Rs. As these vehicles are now reaching an average age of 180,000+ miles (probably higher) I am seeing more complaints about this issue across many automotive forums. Its a $1200 part (OEM) and 5-hour shop time charge, costs that could be the deciding factor between a purchase or "walk away".
My recently purchased T4R's assembly is leaking. Had I known to look for this I probably would have passed on the purchase, despite the great price.
Just my $.02
