3rd Gen 4Runner Lift Information and FAQ's
All right. Time for some community input. I picked up a 97 about a month ago. It drives great and handles all the trails around me like a champ. I have a toytec 3" bilstien/boss/eibach lift kit sitting in the back of it. I had toytec assemble the front coil/strut.
Now the dilemma. I can pay a shop to do it or I can purchase a floor jack, jack stands. and other assorted things that I'll need. The cost savings doing it myself will be about 400 bucks. I used to do all my own mechanical work but stopped about 10 years ago when I moved out west. I work as a plumber so am quite familiar with righty tighty lefty loosey.
The pro's of doing it myself are that felling of pride you get when you do something right. As well as having that jack and stands in case I break anything in my off-road travels. The cons are the usual frustration, bloody knuckles, and lost time that could go towards other pursuits.
So, that's where I'm at. I have a quote from a shop and I have everything I'll need in my amazon basket. I'm just waiting for the UCA's to arrive later this week. So my question to you guys is simple. Do it or drop it off to have it done?
(I'm asking here because I'm pretty sure I know what the majority of responses will be):decision:
Any tips or pics of rigs with rear RC lift and other front lift would be appreciated. Thanks!
I think it should be fine, you are basically talking about doing springe and shocks from 2 kits. If you are going to spend for ToyTec for the front, seems like it would make sense to spend for the rear.... but I'm not here to spend your money :)
Only other thing I'd consider a necessity is a diff drop for the front.
http://www.toyota-4runner.org/sale-...5-trd-coils-5100-struts-rear-5100-shocks.html
Seems like the usual considerations... Are you ok with having the vehicle down for 1-2 days, do you have all the tools and know how.... Plus you will still have to get it aligned and probably at an offroad shop if you install better UCA's. $400 seems very fair if they know what they are doing and includes alignment.
It's a toytec lift all the way around. It just happens that eibach makes there springs. The diff drop is included with the kit. I also have new rack bushings and sway bar bushings for the front and rear.
$400 is the savings I'd see. The shop wants just north of $700 to install it. I'll need to pony up about $300 for tools. My wife is out of town next weekend so I'd have 2 full days to get it done. There's space in my garage to do the work if I get off my ass and organize it a bit. lol
personally i would do it myself. learn a few things i may not know. + have the tools for future mods/repairs. it won't stop at the lift
Control arm drop
I know there are rear Control arm drob to get better stability with the rear axle, what about Front Lower Control Arm drop brackets? Chevys have em, why not Toyotas. Can't seem to find any and it would give me some better articulation I would think.
more spring load questions
Please help, I've been scouring the endless threads on this subject and I'm still confused:
Many threads/tables list 3rd gen 4runners stock OE front coils at 16mm x 345mm and 580 lbsf/in. I cannot tell which years this refers to and if this includes the '99 tall coils.
OME guide shows 880 front coils at 16mm x 365mm and 500lbsf/in (see below).
Why then is the OME 880 considered by many to be a stiffer coil than the 99 talls? Also, OME shows the 881s at 500 lbsf/in as well, yet the product guide lists them as a heavy load application. How does the slightly longer (10mm) 881 spring with the same number of coils and same spring rate as the 880s yield a heavy load application?
Background: I just hit 180K miles and well overdue for replacement of the original stock shocks and coils on all 4 corners of my 2000 4runner 3.4L SR5 4x4. I'm running Dueller AT 265/70/16's and looking for only a mild 1-2" lift with priority given to eliminating the saggy butt. Its my daily driver and I don't off-road or tow much except for the occasional backpacking trip and Baja surf trip when the vehicle is fairly heavily loaded. I would definitely prefer a little rake unloaded than reverse rake when loaded and don't want to mess with air lifts.
I'm considering Bilstein 5100's (4runner) on all four, then 906's in the rear and either '99 talls or OME 880's in the front. Price is a factor with OME 880's coming in at $167 for the pair vs. $260 for new 99 talls from online Toyota parts dealer. I know there's a lot of options and I'll be happy with either front coil, but I would definitely appreciate some input especially on the how/why of the different front coil rates and maybe a direct comparison of the 99 tall coils vs the OME 880's. Or should I consider other front coil options? Thanks in advance.
http://www.arbusa.com/Uploads/PDF/onlineManualsGuides/OME_Guide_current.pdf
http://www.arbusa.com/uploads/PDF/accessorizeYourRig/toyota4Runner.pdf
I've see a lot of discussion regarding the FJ swap and whether or not the Moog FJ coils were a better option than OEM FJ coils. After doing some searching, I've found some of the numbers for the Moog coils, and paired that with some info I already had.
A couple notes:
  1. The measurement for the OEM 4runner front coils is for a V8 4wd. The front coils on a v6 4wd are .2" shorter. 2wd 4runners use a different coil, but so far I haven't found specs on those. All models use the same rear coils.
  2. I couldn't find the spring rate for the front OEM FJ coils. I saw numbers all over the place, ranging from 530 lb / in to 630 lb / in. Most seemed to be in the 550 lb / in range, but from my experience the FJ coils are slightly stiffer than the OEM T4R coils, so that number doesn't add up.
  3. The 540 lb / in number for the Tacoma coils doesn't make sense either. I found the same number in several places (could have been all from the same source) so I posted it. Based on my experience, I'd say the Tacoma coil is stiffer than the FJ.
  4. Some aftermarket coils only show the % increase over stock, so I tried to calculate the spring rate. These numbers are in dark blue and in bold.
It's hard to compare the OEM FJ to Moog FJ coils since I don't have all the numbers. What I can tell is that front Moog FJ coils have the same spring rate as the OME 886 coils, which is very stiff. If I were to order Moog coils, I'd order the 4runner version (v6 or v8 depending on how much lift you want) for the front. I can't say on the rear since Moog did not provide the coil rate for those. I'd expect a minimum of 1" lift in the rear with the Moog coils based on the height. My only concern would be spring rate, and whether or not it'd be too stiff.
The majority of this data was pulled from the following pages:
Coil Rates - Toyota 120 Platforms Forum
Rear Spring Comparison - Page 13 - Toyota FJ Cruiser Forum
Federal-Mogul Resource Center - Vehicle Look-up
UPDATED
Thanks to Andries for some coil information.
Coil Specifications
Front:
STOCK 16mm x 100mm/115mm x 345mm - 7.75 coils - 3.7kg - 580lb/in
FJ 16mm x 100mm/115mm x 351mm - 8.75 coils - ...kg - ...lb/in (+0.24" +...%)
883 17mm x 100mm/115mm x 375mm - 10.6 coils - 5.7kg - 590lb/in (+1.18" +2%)
884 17mm x 100mm/115mm x 385mm - 10.6 coils - 5.7kg - 590lb/in (+1.58" +2%)
885 17mm x 100mm/115mm x 395mm - 10.6 coils - 5.7kg - 590lb/in (+1.97" +2%)
886 18mm x 100mm/115mm x 402mm - 12.5 coils - x.xkg - 660lb/in (+2.25" +14%)
Rear:
STOCK 15mm x 160mm/115mm x 360mm - 6 coils - 2.7kg - 180lb/in
FJ 15mm x 100mm/115mm x 375mm - 6.5 coils - ...kg - ...lb/in (+0.6" +...%)
895 17mm x 160mm/115mm x 390mm - 6.75 coils - 5.6kg - 260lb/in (+1.18" +45%)
896 18mm x 160mm/115mm x 390mm - 6.75 coils - 6.4kg - 318lb/in (+1.18" +75%)
897 19mm x 160mm/115mm x 390mm - 6.75 coils - 7.2kg - 387lb/in (+1.18" +115%)
New rear shocks?
Quick question. Would I need new shocks if I installed a leveling kit in the rear of my 3rd gen 4runner. Tail end sags just a bit.
This is EASILY the best and most thorough writeup of lift options that I've ever seen! Thanks for breaking down all the options. I'm in the market right now toget a lift kit, and this really helped me narrow down what TYPE of lift Iwant to go with. Thanks again!
02 toyota 4runner 4×2
I have a toyota 4runner and its a limited v6 4×2 and i accidently put aftermarket rear coils on the back and now it sags so im trying to see what rear coils are compatible with a toyota 4runner limited v6 4×2 its not 4wd so i need something to get that 1.5 inches back so my suv sits even please help
Rough Country 3 INCH Lift QUESTION****
Hey just wandering if anyone has had issues with the rough country 3 inch lift for 3rd gens.... Im in the middle of installing mine and the springs in the rear for some reason are rubbing against the frame... it almost seems as if they are too wide. Any one know what I should do? or if anyone else has had this problem?
THANKS!
5th gen Bilstien 5100
So I recently acquired a full lift kit off a new 5th Gen. I was wondering if it's at all possible to mount it onto my 3rd gen. The shocks alone are a couple inches longer than the factor ones. ANY INFO WOULD BE AWESOME.
Honestly, I think the majority of the stiffness is due to the shocks rather than the coils themselves. A lot of people pair OME coils with OME shocks, which per their website are designed to control an additional 1000lbs of load. Not exaclty something most people are doing on a regular basis.
I used to have the nitrocharger sport shocks on all four corners and it rode like a brick. Once I switched to Bilsteins (Tundra version) up front and the LC Tociko out back, all was right in the world. It's certainly firmer than stock with the 883s up front, but I have absolutely no problem stuffing tires off road, and I have no complaints on road.
I think if you go with the 880s up front and the Bilsteins you'll be just fine.
can anyone give a ball park as to what a place should or does charge to install a 3" lift on a 4runner? I was at the toytec place in denver the other day. He said they dont install the lifts. dont really have much experience with garages and what going rates are. Dont want to get charged 6 hours if its a 4 hour job. Just wondering what some people have paid to get it done.
A shop should be able to do it in under 2 hours at their hourly shop rate. Realistically if you're being quoted over about $400 then that's simply too much. And that's providing its shocks and coils all around
Yes. A shop should charge no more than $200 to swap out shocks and coils all around.
Thanks for the info. Talked to one place last week and they were talking like $85 an hour 5-6 hour job. Seemed a lot. 4Wheel parts guy in denver estimated about $500-$600 to do it and said that includes the $160 alignment. Brakes Plus is doing alignments for like $58 right now so.
Might just make an add on craigslist to see if anyone wants to make an extra $300 when im ready to have the lift put on, then just take an get alignment from somewhere that wont crack my wallet open
Check with Chris @ Nisstec or Corey [MENTION=116638]InSainFab[/MENTION]. Their labor prices are very reasonable and they are very experienced in installing lifts.
bobdjr41
