zgensler31
Senior Member
Any chance that any of this stuff could be useful? Seems like a good deal if it is.
BILSTEIN SHOCKS & UPPER CONTROL ARMS
Has anyone run into issues with getting an alignment after lifting? Crappy tire wouldn't do it because it's a lifted vehicle (they gave me a bs reason, saying their tools don't fit on lifted vehicles).
I then took it to the stealership today and what a nightmare. They quoted me $100 for the alignment, I drop it off, and then get a call saying there will be an additional $40 charge because the underside of the vehicle is dirty. I later get a call and they tell me that all of the adjustment bolts involved in the alignment are seized and that it's going to be $311 plus labour because of the parts that need to be replaced and that they wouldn't be able to complete it today because of this. I told them to hold off as I need the vehicle the next day. I get there, and they nail me with a $120 charge for the mechanics time (It was now around 6:00 and i had brought the vehicle in at 2:00 for its scheduled appointment.) As far as I'm concerned, that's unacceptable. The incompetent mechanic took almost 4 hours to figure out that a couple bolts are seized and I'm getting charged for the full price of an alignment.
Sorry for the rant, but you can imagine how frustrating it is. Needless to say, I'll be talking with the manager tomorrow.
Any recommendations on where to get an alignment and have others run into similar issues? Are any special hardware/parts required to get a proper alignment with 2.5-3" of lift? (tundra coilover with 3/4" top plate spacer)
become un adjustable? THanks
i'm not sure what shock SS uses but the ones that ToyTec sells are the 6252 shock. Bilstein doesn't really make the shocks specifically for a certain vehicle with the 5125. they just have a list of different shocks that are different length/travel and valving. here is the part list. Bilstein
we made a eye to stud adapter for the shock so it would work on the 4runner and it also gives it another flex joint at the top of the shock. I have those 5125's on my 4runner with the 8.5 wrap LC and i love them. they ride great and have a ton of flex
:thumb3:
Questions for those with the 861's. I've had the 891 springs with 1.5" spacers for about 2yrs now and with my 300+lb storage/tool box, the rear has sagged to be 1/2 an inch lower than the front. I want my rake back! I want it setup so that it will settle and still be at least an inch higher in the back with a 300lb load. Also be nice to not use the spacers.
According to this Cruiser Outfitters
Free Height
891- 16.5"
861- 18.9"
850- 19.5"
850J-20.7"
So my current setup being 18" total, I'll need 19.5" to accomplish my 1" rake. But I also intend on tossing more weight on with a rear bumper with tire carrier and fuel cans. So should I just go with the 850J springs? I know it seems like a lot but we know it's going to settle.
And while I'm back there I might as well swap out the Pro Comp 9000 shocks for something with more length right? Sooooooo......
Thanks for the help.
hey steeze, what shock is the 5125 your are running ment for or slated for? im looking to order my shocks and am getting tundra 5100 for the front, and want to get something for the rear, im using 8wraps for now, and have some armor and carry some weight so i want to stay with a quality shock.
does anyone know if the tundra 5100 rear shock will work with my set up? . i know the FJ80 shocks are the ideal but the place im going to order from does not carry the 5100 series for the FJ80.
Toyota 4Runner Forum - poleclimber63's Album: 1998 SR5 V6 (auto unfortunately) Start of a Project... - Picture
I'm blown away by the choices and what you guys are doing with your 4runners!! Unfortunately, my sights are somewhat lower, in that I definitely take my runner into the bush, but not mountain climbing! My main goal is to tow my sportboat down to the lake, as you can see in the pic above, but you'll also notice the HUGE sag with the boat hooked up! I'm not considering a all-around lift now ($$) but require a firmer rear suspension to handle the occasional trip to the lake. I estimate a tongue load of 350lbs., one of the forum members suggested Firestone load bags. Does anyone have any other suggestions--- I put "load levelers"(firmer shocks with an extra coil all in one) on my old Chev which did the job, but this was a bigger truck.
I appreciate any suggestions! Thanks!
