3rd Gen driver's seat wear - FIXED for free!
angus
So I've only had my '99 limited for couple months and overall it's in great shape except for the one thing - the driver seat side panel of the leather seats...
As most of us know it isn't leather - so many manufacturers make the sides and back of seats in vinyl to save money and the 4runner seems to have this issue a lot - for those who don't know, I am referring to the part of the seat on the lower cushion that faces the drivers door.
The worst part is that it's the first thing you see when you open the door and after lifting it, it was even worse because it was more noticeable.
Since a few days after I bought the truck I had the idea that maybe, just maybe I could switch the seat cushion leather from left to right - making the cracked vinyl "invisible" since it would be against the console on the pass side after.
Well I DID IT!!!!
I removed both seats and studied them, after removing the plastic side covers I discovered that the two lower seat frames were held on only by 4 bolts - and the lower cushions and frames are - get this - TOTALLY IDENTICAL!
They are even stamped with L and R on each side of each part to signify where to put the wires if it is used as left or right.
The only hiccup in my project was my '99 had the weight sensor on the pass side to cancel the airbag if you put less than a certain weight on it -
I started to remove all the hog rings to pull the leather off as I was going to swap the covers, then I realized the sensor was just a ribbon cable glued to the seat. So what I did was carefully peel it off (with aid of a razor blade) You want to be extremely careful not to cut or rip the cable - I then peeled back the drivers side leather (pulled a few big rings) just enough to expose the part where the sensor sits - the foam in the driver seat is even indented in the spot where the sensor goes. As I said the L/R parts are identical!
I used some 3M 90 spray to glue it back in place and buttoned everything up!
Now my driver seat looks brand new, the ripped/cracked part is super unnoticeable because the damage is sandwiched against the console on the pass side and even more so because even the worn part of the bolster on top (mild wear) is further from your eyes when you open the door - nobody would notice if you didn't tell them!
Completely free repair and took me maybe 1.5 hours.
It's more of a trick than a fix. It's been done before. The worn passenger seat would still be an eyesore to me.
Nice fix! I had the same idea, have the sport cloth seats and my driver seat is getting worn in the same spot. I think I should do this before it gets ripped completely.
I'm surprised how well it works - yes it's a trick but as I said, the part near the console isn't where people eyes go, it's the sort of thing that would only bother you if you knew and started looking for it.
A friend remarked that it might take someone a few days or more of driving the truck to notice.
If you do not have the airbag sensor, you could swap them in under an hour.
Ill have to look at my old seats, I want that sensor in my scion xb seats.
Hahah - I thought you meant that you wanted it in a scion - I didn't see that you swapped XB seats into your runner - If you originally had the sensor in your seats it'll be so easy to swap it into the XB seats.
I did think about installing a switch inline with the sensor to disable the airbag.
Im just concerened that if i got in accident with someone in the seat, i wouldnt want it to malfunction.
Yes, the sensor is there so that if the person is below a certain weight then the airbag will turn off - also a variety of other reasons like of you put groceries or a child seat etc.
Just add it to your scion seat - not hard to do.
I Did the seat bottom swap last week very easy.
Hopefully my Coverking Premium Leatherette Taupe seat covers arrive this week.
On my '02 Limited with leather, it did not work. The frames are different and the covers have to be swapped. Still worth the effort, though.
Very strange that 99 and 02 seats would be different - are you sure they were not the same?
Do they still have 4 bolts holding the lower seat cushion frame to the rest of the seat?
I had done this a while back and posted it in the "what did you do today" thread and my build too. I guess not too many people saw it lol. Great minds think alike.
Unfortunately now just after a few months this side has begun to crack as well and a hole had already formed on the upper seat back....
I figured someone else would have done this too...
I can't believe the wear came back that fast - I guess the vinyl is old...
BTW I suppose that one side benefit is that if I want an upholstery shop to repair the cracked seat, I could now remove it and give it to them and still be able to drive the truck!
Deka
