3rd Gen FAQ Thread
ChildrenOfBodom
Moderator
Honestly...
I think we need a 3rd Gen FAQ sticky, a thread listing all of the things people always ask instead of cluttering up the whole top of the board with stickies. Understood that there is a tutorial and documentation reference thread, it's a great resource, but it's not quite a FAQ.
4WD lever/pushbutton thread, the lift thread, the 99 mid gen upgrades, the rear sag thread... all prime examples of very good informational threads that should be found in one place, without them all killing the first page.
Tire size is a good one, ECT PWR, clock fix, rear axle seals, pink milkshake, just the generic.
I'm sure we're all as sick of it as the next guy. I am sure there are tons more. These are just the ones I came up with after a few minutes, and more can be added. What do you say mods, make this the main FAQ Thread instead of filling the board with stickies?
1. I want to lift my 3rd gen. What are my options?
http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.html
2. What is the difference between the newer and older 3rd gens?
http://www.toyota-4runner.org/3rd-gen-t4rs/44297-99-mid-gen-upgrades-w-pics.html
3. My rear suspension is sagging, what is wrong?
http://www.toyota-4runner.org/3rd-gen-t4rs/48552-about-rear-sag.html
4. What is the difference between lever controlled and push button 4WD? Which 3rd Gen comes with either, etc?
http://www.toyota-4runner.org/3rd-g...rs-3rd-gens-transfer-case-awd-multi-mode.html
5. Will 99+ Headlights fit on my 96-98? What brand should I get?
http://www.toyota-4runner.org/3rd-gen-t4rs/78462-99-headlights-97-question.html
http://www.toyota-4runner.org/3rd-gen-t4rs/75932-headlamp-replacement-advice.html
6. What is ECT PWR, and what does it do?
http://www.toyota-4runner.org/3rd-g...tires-wanna-stabilize-your-mpg-take-look.html
7. How do I fix my 3rd Gen clock?
http://www.toyota-4runner.org/3rd-gen-t4rs/67508-3rd-gen-dash-clock-fix.html
8. My rear axle seal has blown. What do I do, and what has caused this?
http://www.toyota-4runner.org/3rd-g...e-information-replacement-thread-3rd-gen.html
9. My 4Runner's transmission has overheated/I have suffered a pink milkshake.
http://www.toyota-4runner.org/3rd-g...radiator-design-questions-pink-milkshake.html
10. What are the biggest tires I can fit on my 3rd Gen with stock suspension? 15" or 16" rims:
http://www.toyota-4runner.org/3rd-g...size-tires-stock-15-inch-rims-99-4runner.html
11. I want to change my interior lighting to LED's. What will I need?
http://www.toyota-4runner.org/3rd-gen-t4rs/35104-led-lighting.html
12. How do I improve my 4Runner's throttle response?
http://www.toyota-4runner.org/3rd-gen-t4rs/45445-how-get-better-throttle-response-free.html
13. How can I improve my 4Runner's performance without spending a lot?
Toyota 4Runner Highlander Deckplate and Air Filter Modification
http://www.toyota-4runner.org/3rd-gen-t4rs/74287-isr-mod-write-up.html
14. How do I change my tail lights?
http://www.toyota-4runner.org/3rd-gen-t4rs/48278-led-tails.html
15. My VSC TRAC, TRAC OFF, and Check Engine light have come on!
http://www.toyota-4runner.org/3rd-gen-t4rs/68529-christmas-tree-vsc-trac-engine-light.html
16. How can I turn off traction control and VSC?
http://www.toyota-4runner.org/3rd-gen-t4rs/61795-quick-andy-mod-question.html
17. How can I engage my locking rear differential in 2WD, 4HI and 4LO?
http://www.toyota-4runner.org/3rd-gen-t4rs/46404-grey-wire-mod-4runners.html
18. How can I remotely disable my ABS on my 96-98 3rd Gen without removing it entirely?
http://www.toyota-4runner.org/3rd-gen-t4rs/77665-abs-disable-older-3rd-gens.html
19. Is there a guide to installing an ARB or offroad type bumper?
http://www.toyota-4runner.org/3rd-gen-t4rs/78268-arb-bumper-installation-3rd-gen-t4rs-step-step.html
20. I want to install a factory E-Locker on my non-equipped 4Runner. How do I go about this?
4Runners.org - 3rd Gen 4Runner E-locker Retrofit
21. What is SeaFoam, and how do I use it?
http://www.toyota-4runner.org/3rd-gen-t4rs/7330-how-do-i-seafoam-my-99-4runner.html
22. What color codes determine what size Land Cruiser Spring to lift the rear of my 3rd Gen?
http://www.toyota-4runner.org/3rd-gen-t4rs/66753-lc-coil-spring-color-codes.html
23. Guides to replacing all of your 3rd Gen 4Runner's Fluids
4Runners.org - Changing Your Front, Rear, Tranny & Transfer Case Fluids
Dropping Pan And Flushing Transmission
24. Where is the fuel filter located on my V6 4Runner? How do I change it? (Not the same for 4 cylinder owners)
4Runners.org - Replacing the Fuel Filter on a 98 4Runner V6
25. I've noticed my factory fog lights disable once my highbeams are switched on. How can I prevent this and keep all lights on?
Factory Fog Lamp Re-Wire Mod - 3rd Gen 4Runner - YotaTech Forums
26. What is the Diff or Differential Breather Mod? How do I do it?
http://www.toyota-4runner.org/off-roading-home-monst4rs/123-breather-install.html
27. My power antenna does not seem to work. How do I go about replacing it?
http://www.toyota-4runner.org/3rd-gen-t4rs/64398-power-antenna-replacement.html
28. I've decided I dislike my power antenna, are there other options?
The "Taco" Whip Antenna Mod
29. Is there a guide showing how to install a snorkel on my 3rd Gen?
http://www.toyota-4runner.org/3rd-gen-t4rs/64284-new-snorkel-3rd-gens.html
30. My truck starts, but only sometimes. The battery is fine, everything seems normal... what's wrong?
http://www.toyota-4runner.org/3rd-g...arter-contacts-removal-thread.html#post530199
31. How can I disable my Daytime Running Lights on my 2000 4Runner? My bulbs keep dying and I am going nuts!
http://www.toyota-4runner.org/3rd-gen-t4rs/29681-how-disable-drl-your-3rd-gen-earlier-models.html
32. How can I disable my Daytime Running Lights on my 2001-2002 4Runner? I'm going as crazy as the other guy!
2002 4Runner: DRL Disable With On/Off Capability - YotaTech Forums
33. What is the Tundra Brake Upgrade, and how will it benefit me?
Installation: Gen 3 Toyota 4Runner Tundra Brake Swap: Off-Road.com
34. Will the 231mm Tundra Brakes fit with my stock wheels?
http://www.toyota-4runner.org/3rd-gen-t4rs/78687-16-inch-rim-231-a.html
35.
I agree this should become permanent. I already used it twice. The search function can take hours sometimes to find what you are looking for.
Thanks for posting this
Gary
While I agree that this is useful (great job making it), I would like to see the sticky's consolidated if this gets added. Maybe combine this, "Lift Info" and "about rear sag" into one thread. No reason to take up half of the first page with sticky threads, limiting the number of new, useful threads that are seen on the first page.
Also, there should be some sort of "Is this a good deal?" thread. I dont know how many posts are asking if their purchase would be a good one. Yes your one owner 4runner with 120k is a good buy, No the 4runner with 445k and has holes 10" wide from rust is not a good deal.
The problem is we will still have people skip right over the FAQ sticky's and fail to search only to post a new thread on a over done topic.
Exactly. And I think the problem is everyone is too nice! haha. Those threads still get answers over and over. Instead, the answer every time should be: Please delete this thread and search.
Thanks guys, I appreciate the suggestions and support.
As far as people still posting, it is inevitable. I suggest we now direct them towards this thread so they can determine which item they need help with. It would save tons of clutter between "What size tires can I fit stock" (that question alone, jesus!) or the less common ones like "ECT PWR light came on!!" or "what is a spacer lift"
I added a few. The more suggestions the better
The one about LC color codes, though, do you think that should be inputted into the Lift FAQ?
I was trying my best to keep the links within T4R.ORG... but okay. There are some great links and resources elsewhere.
I thought forums were exactly for this reason. There is a wealth of knowledge on this forum and people benefit from it daily. I agree a search is in order, I always search before asking a question. If I don't find exactly what I'm looking for and have a quick question I'll ask. What the OP is trying to accomplish I think is a great idea. That way those that get offended when questions are asked over and over don't have to visit that part of the forum. And those who would like an answer would have a central place to start their search. Just my .02
I know this feeling. However, when you're a newbie to a forum, like me on t4r, and ask a redundant (to an experienced poster) question, and the reply is, "use the search feature". This makes said newbie not want to post anymore on the forum for fear of feeling like a dumb***.
From experience on another forum, I think it is always a good idea to direct people where to go to find the answer or go ahead and answer the question. I'm sure the 'powers that be' of t4r would appreciate that :)
Wow, so the Tutorial and Documentation Reference thread which I've never ever looked at with it's boring name apparently covers a lot!
Yay, way to be a good example of failing and prove my own point... :redbrick:
Sounds like it should be renamed alright!
^agreed.
Without people asking questions and making suggestions it wouldnt be a forum, and would just be a boring website.
I like this thread! I think it will work out great for everyone, not just newbies. Sticky please!
And I think we can all agree searching can be cumbersome sometimes because of wording, technical terms, spelling and such. I know we have all been there when you know there must be a thread on a certain subject, but you spend forever trying to find it before you finally give up and post a new thread.
I agree. The "search, dummy" refrain is over-used some places. A newbie's problem is often not knowing the correct term to search on. Many forums to which I belong have spastic search functions and I would never use them.I'm sure some people come here not knowing that this forum has one that works pretty well. It is much better to suggest something is covered in a FAQ area and give newbies a place to learn. Oh, nice work on this, CoB.
