3rd gen lean. Fix?
Never had that problem. SS1.2 sat level, OME 3" I have on 01 sets level.
Both are side specific.
Bought toytec superflex which are side specific and still had the lean. Swapped for ome861 still have side lean. Could be a hit or miss. Easy fix. OME sells 5mm and 10mm spacers.
This is why I am confused, I thought replacing struct and spring with the same on both sides would make it level? Pics are from the front
You miss understood my post, SS1.2 & OME 3" are side specific, driver side is longer front and rear. Refer to post 20.
Your front pics show things are assembled correctly.
Wondering if the 1/4” spacer will give me enough correction for the 1.5” difference on the front or will I be better off just adding one ring only in the driver to the top ring of my 5100.
Assuming the correction of the front will fix the rear
Add 1/4" spacer to driver front, my 881's had 1/4" spacer at lower perch.
Pull your rears and swap, OME 906 rears are side specific just like my 890's.
Doing the two you should be good, how mine worked out anyway.
awesome this gives me some hope haha. Just want to confrim the placement of the spacer itself. Does it go on top of the top hat and then squeezed in between the top hat and the mount of the top hat?
