3rd Gen T4R DIY Maintenance, Repair and Modification Videos
Would a used one do?
Does it really have to be linked with the Vin?
Sent from my SM-A705W using Tapatalk
ECU Replacement
Also, google 2000 4runner ECU replacement
I personally would not want the hassle and not being able to pull codes off the vehicle before purchasing it means you're buying a pig in a poke
Like I said, I'd find another truck, but that's just me
If you can find the correct used ecm for it then it would work (if that is the problem). Needs to be the correct year, engine, transmission, 2wd/4wd, and emissions in order to interchange.
I'm about to buy a used Toyota 4runner 2000 3.4L 4x4
The truck won't start because it needs a new ecu...thats what the owner says. Something that has to do with the vehicle VIN #
Can it just be restarted?
Dude, just walk away from this one. This guy is obviously trying to pawn off a problem vehicle. Why would you risk buying something you don't get to start and drive to verify everything is working like it should. It could have major drivetrain issues or major electrical issues and you wouldn't know.
If anything, tell the guy you'll take a look at it once he gets a new ECU and he can show it runs and there's no major issues.
If you move forward and buy this rig, you deserve any and all problems that follow. I'm not known for having much of a personal filter so why change now. You'd be an idiot to buy that rig.
Transgo 340HD2 Reprogramming Kit Install - A343F A340E ('85-'08)
check out this schweeet transGO reprogramming kit we installed on Chris's truck! ( [MENTION=271883]T4topher[/MENTION] )
<iframe width="560" height="315" src="https://www.youtube.com/embed/6FVHE7o2VRo" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
1997 4runner front door
Quick question I need a front door for my 1997 4runner and I found a front door but it's a 1998 4runner, will there be an issue installing the 1998 door to the 1997 4runner ????
Will you move over the inside panel and window switches? If so, then probably not. There are differences between Limited and SR5 and base models. 97 and 98 are pretty much the same electrically.
Knock Sensor and Knock Sensor Wiring Harness Replacement
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZMqKuVGswdY" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
ARCWORXS Shock Relocation Kit
<iframe width="560" height="315" src="https://www.youtube.com/embed/-PnYO6Hro8Q" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
3rd gen - CV Axle replacement issue
Howdy everyone,
I am just now having an issue while replacing one of my cv axles on my 1999 4runner. I’ve installed the new cv axle that’s from autozone as youtube videos have instructed but am running into the issue of the inside end of the half shaft having around 2-4mm of linear wiggle. I’ve tried hammering it in more to no avail, only leading to slight mushrooming of the other end because i’ve hammered so much (luckily i was still able to screw on the castle nut with no cross threading).
Is this wiggle normal? Or should I try to reinstall it or replace it?
Here is a youtube video link: 3rd gen toyota 4runner cv axle issue - YouTube
Cheers, let’s hope I can fix this soon and get home!!
Howdy everyone,
Howdy everyone,
Some play is expected - did you try pulling it out by hand after installing it? Typically if you can't pull it out by hand, the c-clip is seated and you are good to go.
I have had to do this many times
Do you have water dripping from areas of your headliner? Do you have a sunroof in your vehicle? If the answer is Yes to both questions, watch this video to try to isolate where your leak is coming from. It could be because you have clogged sunroof drains that need to cleared.
You can clear your own drains with a little persuasion from weed whacker line or some other type of solid line you can snake in the drains.
**In the video, I say the driver side rear drain travels down the B-Pillar but it actually travels down the C-Pillar and then over the wheel-well.
**Some people have employed the use of compressed air but you need to be careful if you choose this method. If you use too high of air pressure, you could force the drain tube off the fitting and then you'd be forced to pull down your headliner so you can reattach the drain tube.
<iframe width="560" height="315" src="https://www.youtube.com/embed/qalXo4etX3Q" frameborder="0" allowfullscreen></iframe>
Great video
If you're in the market for an aftermarket bumper for your 3rd Gen 4runner, and you were considering buying an ARB bumper, we have a video you can use for the install. Even if you choose another brand of aftermarket bumper, the video does still have some value because we show you how to get your stock bumper off.
Enjoy the Show!
<iframe width="560" height="315" src="https://www.youtube.com/embed/Wey2f8n0Klc" frameborder="0" gesture="media" allow="encrypted-media" allowfullscreen></iframe>
ECGS Toyota 8" Rear Differential Regear / Rebuild
<iframe width="560" height="315" src="https://www.youtube.com/embed/W-GN-1bgZwU" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
t
t
Just 8 minutes in, and this is very helpful. Thanks!
t
So now I know where my 7.5 clamshell came from!
Great vid, Tim. Thanks!
ECGS Toyota 7.5" Front Differential Regear w/ Eaton E-Locker Install
<iframe width="560" height="315" src="https://www.youtube.com/embed/sUzVndDO8To" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
t
