3rd Gen vacuum line(s) leak? charcoal filter?
Derekl36
3rd gen 2000 toyota 4runner v6 3.4L 2WD
I recently had my drive line snap at the u joints while on the freeway. it banged up the gas tank and exhaust. when it hit the gas tank it hit so hard it snapped the plastic tip off my fuel pump to the rubber hose. Ive replaced the fuel pump as well as the return line that got kinked when drive line smacked it against the tank, the drive line as well. Car starts fine idles fine but when i put it into gear gas pours out the overflow tube? from the charcoal canister i believe, it runs its way down to the driverside frame undereath motor.
ANy suggestions would be greatly appreciated.
I cant find any leaks or other kinks in the lines but that still doesnt mean there isnt.
everything i read says replace charcoal filter but i want to be certain before i blow a chunk of money on one.
Checked all wire connections as well.
utkrstam
