3rz running rich
cantaloop
Posted this in the 3rz only thread but i got nothin so figured i'd repost. Im a 3rz 4runner owner and mine has been running very rich for a while now. You can smell it while driving around town with the windows down, it's definitely gas. Thought it was my exhaust leak at first so i replaced my manifold with a header. Stopped the leak but still ran rich. So i replaced my upstream o2 sensor, cause i had a P0136 show up. Still didnt fix anything. Rear o2 was replaced when i got the truck so no issues there. What else could be causing it to run so rich?
What mileage are you at? Is it running well? Is it possible you could have an exhaust valve clearance too tight and not sealing properly? -as in some fuel escaping past an exhaust valve on the compression stroke? I would think you would notice something in driveability though...
This is just a guess but the exhaust valves are a known issue on this engine.
It runs pretty good, idle is steady around 650 when in drive. I can hear a ticking when at higher revs that sounds like it could be valve related, doesnt sound like an exhaust leak. May have smoked a valve when i had a big exhaust leak that i didnt fix for 8 months.
2001ATL
