3vze Engine Pull Help
Badbob
Hey guys
I think I got everything disconnected to pull my 92 3vze short block.
A/C and PS off
Exhaust off
Trany bolt off
4 Engne mount bolts off
Just for kicks I puta jack under the tranny and lifed abut 1/4"
The tranny and engine lifted and so did the vehicle!
I thoughti wuold have lifted the engine off the mounts.
Any ideas of thoughts?
Badbob
Did you get the torque convertor bolts?
Helo, thanks!
I got all the tranny bolts off--
where are the torque bolts? do they sit slightly farther back from the tranny bolts? 17mm? Tranny bolts were smaller 14mm.
How many?
thanks, I'll look again at the FSM
Badbob
Pull the 2 cast iron brackets That bolt to the bottom of the bellhousing...then remove the sheet metal that covers the bellhousing under the oil pan. There are 6 bolts that hold the flywheel to the converter.
Ok, thanks, didn't see that. I'll take a look and pull those out.
Badbob
