4.7L V8 Timing Belt Change Plus More
If you put the pusher fan on a manual switch make sure you use a power source that is hot only when the ignition switch is on or your risk draining your battery if you wire it direct to the battery, etc. if you forget to turn off the fan when stopping for a while or parking it.
Will do thanks for the info. Were did you wire yours into?
I don't have a pusher fan on my T4R, just didn't want you to end up with a dead battery out in the middle of nowhere.
Yea I should have mentioned that. I don't run mine much and it's pretty loud because you can hear it over the engine idling, and I usually air up my tires and do a walk around after hitting the trails anyway, so it doesn't stay on very long. In your case with so much travel and having it on most of the time, you could easily forget that it's on and walk away.
