4 wires away from remote start...
4RunnerChaos
Alright guys I'm almost done installing a remote start system on my 98 limited. The last four wires are two 12 volt positive kill switch wires and the other two are ground kill wires
I can't reach the brake switch to use the wire on that for the positives... Is there any other way to get to that wire without dismantling everything? Or an alternate wire that would receive a +12 volt charge before putting the truck in gear?
And where would a spring loaded grounding switch be mounted under the hood but close to the firewall?
Any suggestions are welcome. I could omit them but I'd also not want to accidently start the truck when I'm rolling around on the ground under the truck... Haha
chasebradshaw
