4R from North, *Accessories build time.
Well today i tried to get lost, so explore some new places.. mostly to get a place to cook my coffe. [emoji1]
Sent fra min WAS-LX1 via Tapatalk
Your 4R looks very good, and the landscape is beautiful!
Thank you, what i don't like so much, is the extra Ez flares that is visible under on the plastic fenderflares, they work pretty good and build out to keep the tires under the flares so it passes the technical controls when i got license plates on it. i want to take it off again but they are glued with 3M tape on... so will see later. i will just try to get used to it.
Will possible look a bit better with the 32" i have..
Replaced the valve cover gasket yesterday, also re-seal the o-ring with liquid gasket cause it caused a oildamp leak as well. Hope the burned oil smell will go away now. Gave the cover a clean..
Also done with some support feet for the plates that makes my storage box as a bed. not yet done with the side plates cause have to much stuff to do. Also gonna update the stereo a bit so found some cables to use from another car.
Thank you[emoji846]
Yesterday i replace the older positive cable to a thicker one.. cause im gonna have some electric devices in this car as well... also prepared some feets for the supports for the sideplate. the negative one i need to install them when the sideplate is down... but i think the sideplate will mostly stay down anyway.
Some more stuff hooked up. had to go with new amps cause of the size of the box, so they fit perfect.
Quick question about your rust work, what is the yellow tinted product that you put on the repaired areas called?
It is a 1-comp thin layer of acid filler, mostly use to get the paint products to stick very well. it is good to use on aluminum as well.
It can stay on clean steel a longer period without beginning to rust again. So i use it mostly a day or longer before i paint over it or so. the brand is Sikkens and is called washprimer. only mixed with some thinner.
i love car audio, so i will use this enclosure local when im not out on adventure or so. it is not so big, big it takes place if i need bedplace [emoji28] also begin to upgrade some standard ground cables like tge groundwires from engine block.. will also upgrade to new cables from battery to chassies and also bigger batteryes. i Want to install solar panel or so later.
Thanks.
Well about the tweeter holder im done with that part last week or so. . it got a bit big but it plays as i wanted. may look a bit funny tho. lol
delislerebecca
