4Runner-less
Bouncnb
Well, I have been without my T4R since last Friday. Problem started the day before. Here it goes:
Coming home from work my truck studdard once. I didn't think much of it because I was wearing new boots and thought my foot slipped. But, the next morning I came out to go to work and my remote thing didn't work. I thought maybe the battery went dead on it. So, I unlock it with the key and tried to unlock the other doors, but no dice. So, then I thought my battery was dead. Odd thing is, my truck started right up. First thing, after I started my truck, that I noticed was the oil press light was slow to go out. Then I saw my check eng light was on, VSC Trac, VSC Off and Battery lights were on. Then I tried to give it some gas and the eng didn't accelerate until the gas was pushed passed halfway. Then at that it was slow to rev up. I turned off my truck, called Toyota and they said not to drive it, call a tow truck and get it up there.
Later that day they called and said that the alternator was bad. Wasn't charging up the battery enough and that was causing the problems. They said that some of the signals for different thing go through something like a battery bus. (That is what we call it on aircraft.) There were numerous faults, including TPS, O2 sensor 1, O2 sensor 2 and some other stuff. I really didn'tpay much attention after that. I was happy they found the problem. They said they ordered a new alt. and that it would be in on Tuesday.
Fast forward to today. I called the dealership and they said the part came in, but there are still some errors/faults. The tech didn't know what was causing it. They called the regional tech rep. He couldn't find the problem. The dealership called me back later in the day and he told me that they are waiting for Tech headquarters people in Cal to call back with assistance. They are thinking that my computer might have gotten fried. Hopefully I will know something tomarrow.
One thing I like about having a warranty is I get a free rental from Toyota, plus I don't have to pay for the repairs. I will say that I don't like the new Rav4. It is gutless and rattles like crazy and it only has 4,700 miles on it. I will let y'all know what happens.
Anyone else have any ideas as to the problem?
Yes it is a 4cyl. And it has no cajones!!! With the a/c on, when you hit the gas, it feels like it is going to die because it boggs down sooooooo much.
As for you 4R, I am still waiting. Looks like another weekend without it.:( As for the cost of an ecu......you are right, I am sooo thankful that I don't have to pay for that or anything else that might be the problem.
Sorry to hear about your problems. This is definitely not typical of Toyota. Just curious, do you have a remote starter? If so, that could be part of the blame for your problems. That caused a lot of grief in my truck!
I thought the RAV4 would be a great rental. I heard from some people that the new RAV's rattle like crazy, ride is bouncy, and the road noise is annoying. You should request an FJ Cruiser loaner instead! :D
FJ would be nice, but it was either a Rav4, xA or Corolla. I am now wishing they gave me a xA. Anyway, Toyota called today and said they are ordering an ECU. I am going to call back on Monday to get a status on when it should be here. I read somewhere on here that someone had to get a new ECU and it was back order for theirs and it took about 20 days!!! I hope that is not the case. If so, I think I might request something else, vehicle wise.
Well, they got the new computer in and installed. Thats the good news. The bad news is that didn't fix the problem. They are still getting the same faults. Now they say they are going to start looking for corroded or melted wires! Does anyone else have any other possible ideas? Serious ideas, not ones like sell car...yadda yadda yadda.
Any aftermarket alarm, remote starter, or radio installed? This sounds like a problem one of the above can be causing.
The only thing I have installed is a Scion Stereo and a Dension Icelink. No remote start or alarm. Nothing has been spliced, diced or julianned.
I'm stumped. You may have been the lucky one in a million to get the lemon Toyota.
Toyota called today, they said that they have the sales department area getting another 2004 in and they are taking it back to the service dept. and the regional guy is coming back, just for my truck and they are going to start swapping/replacing all kinds of stuff. He mentioned something about a THROTTLE POSITION RELAY BAR.
This is getting really annoying. But, atleast they are trying anything and everything. I am impressed with what they are trying to do to get it fixed.
Looks like they found the problem with my truck. They replaced a fuse block. Not sure which one, but thats what was replaced. They want to keep it over night and check everything tomarrow to make sure everything works as advertised.
That makes sense because a blown fuse can cause all of those fault codes. When I had one fuse blown, my dashboard looked like a christmas tree. I actually had to get the fuse block replaced on my 2003 Sport. My 12 volt outlets in the truck went and it wasn't only the fuse. Good luck and I hope that fixed your problem
Another update:
They also found that the gas pedal assy, (some sort of rod or something) is bad. They are ordering that, and the should have it by Thurs. or Fri. I could have my truck on Friday or the first part of next week!!!!
I was once messing around with the gas pedal. If I remember correctly, the mechanism is all plastic.
Been a long without the ole runner ... huh?
Well, I got my truck back today. But, now I found a couple of things that are wrong. Drivers mirror, mirror itself, is discolored and the center console is gouged. They are going to order and replace those as they were not damaged when I dropped off the truck.
About the electrical work, everything seems to be working as advertised. Luckily it was covered under warranty. The cost, not including the rental/courtesy car Toyota gave me, was about $4,300.
I am just happy to have my RUNNER back!!!!:bouncy2:
Well ain't this about a bi-otch!! I gotta take my truck back to Toyota. Now the 4wd system won't engage. I was going to need it today. Had to get out in the field and do some quick maneuvering as OpFor (Opposition Forces). Hopefully its something associated with the computer swap and they just need to reset.
New update: OMG.....they still have my truck. THe warranty cost is at about $8000 plus the cost of a courtesy car. Also, I contacted a lawyer today back in Mississippi and have to fax his a bunch of stuff and I might be pursuing a lemon law buy-out of my truck. Will let y'all know.
BTW....4wd system........Changed so far: 4wd selector switch, solinoid, actuator, transfer case and now 4wd computer. (Waiting for the computer to come in!)
