freshedie92
Car: So I have a 2004 4runner v6, purchased with 160 on dash, actually 400+ on carfax ($3900). Ran great, but found out it had a slight exhaust leak into cooling (after lots and lots of diagnostics). Other prob too but they're fixed now.
Rebuild: Purchased this thing for a road trip to Mexico, made it fine, and took it to a mechanic for a rebuild. I have worked with him in the past and family recommended him. Rebuild went well, truck is running well, but as I got in I noticed the 4lo light was on with the green 4wd light. But it was driving normally (4lo not engaged). P1792 CEL on.
Issue: I switched it to 4hi, backed up, went forward neutral, over and over to try and get 4lo light off. No luck. I did not try to use diff lock, and the system had been working fine before. I dont actually know if its in 4hi, it could be in 2h, but the car thinks its in 4lo. When i switch it to 4hi the 4lo light blinks and there is warning sound until I move the switch to 4lo. I drove it over 65 but I did not note the rpm so I do not know if 4th gear is working, but I think it is.
Attempts: The mechanic said as soon as they turned it on that the 4lo light was on and making the sound. They said that they have double checked the harness and nothing is pinched and everything is connected. Two other mechanics came with "advanced diag systems" and everything is "good". I am not entirely sure what diagnostics they have done, but they mentioned that they did a recalibration.
IMO if nothing was damaged when engine was pulled, then system just needs to be reset because it woudn't go into 4hi on its own. But I am afraid that something was pinched.
What do you think? What diagnostics/recalibrations would you do? If they cant figure it out I will start with battery post, then zero point cal, then 4wd comp disconnect.
I planned to 4 wheel out here but it might not be possible
any help is appreciated.
