4th Gen: How did you plug the holes in the wheel well?
So has anyone found out if Toyota makes plugs for the other holes on the wheel wells? If so, got part numbers. If not, what did you do to fill these holes?
For the smaller holes I went to home depot and looked in the screw section. They had some white plugs that fit perfectly. I used the Toyota plugs fort he bigger holes.
dealer rip off
Don't get me started on the dealer ripping me off.
I needed to replace my cabin a/c filter. I asked their price while getting an oil change: $34 each was the part person's reply.
$34!
I told him I could order it online for $16. He immediately matched it.
Bastards.
I feel pity for the little old ladies who get ripped by these cartel members.
I would have paid $20 each should that have been the dealers original standard price. I support brick and mortar business whenever possible. But cold hard gouging is unacceptable.
Again, bastards.
I did the Toyota plugs on the large holes on each side and used some clear sticky plastic tape on the small holes. worked great no problem in the last several months. Tape is holding well. I really don't think you would get much dirt through the small holes even if you leave them open. Up to you. You might stick some used chewing gum in the little holes :)
I used "Marine Goop" to plug all the holes in my 4Runner fender wells. It forms a perfect seal, is clear in color, and filled the holes flush with the surface. Not noticeable at all. The plugs will last the life of the truck but could easily be removed if necessary. Silicone caulk should work fine too (I believe it can now be purchased in colors).
are these rubber as well? got a part#? oh and can some1 PLEASE MAKE THIS THREAD A STICKY? thanx
MAN I finally looked into the wheel well, there is a GIGANTIC OPEN GAP (into the engine bay) by the struts!!! it's almost useless plugging these small holes when a big black hole exists...
The reason we have found that it is useful to plug these smaller holes in the wheel well covering area is that as the vehicle goes down the road/off road the tire will throw dust/dirt around in the wheel well. since these holes are in the wheel well and open up into the engine compartment it causes excessive amounts of dirt/dust to accumulate in the engine bay. By just plugging these 6 small holes it makes a huge difference. Try running your 4runner for a year without these holes plugged and then have your engine cleaned and plug the holes and then see what happens over the next 12 months. Good luck.
i just went to home depot. this part didn't exists...
yabedude said:
I picked up 2 Master Plumber (Home Depot) Diaphragm for American Standard Aquaseal cartridge.
ULN AS-2 UPC code 7 73497 00006 6
Re: Re: 4th Gen: How did you plug the holes in the wheel well?
My Home depot didn't have it either, I went to Toyota dealership and ordered the Toyota plugs, they fit. The Toyota part number is listed in this thread.
Het TITMAN, IF you notice, those huge gigantin holes by the struts are not in the direction of water flow and other flying dirt.
lols funny man, here's wat the "TT" stands for (see pic). but i certainly do admire dat part of the body of the appropriate female :D
another. yes both cars are the Twin Turbo models. BTW, I'm sure some of the flying debris n the wheel well will make it thru into the engine bay bec of the huge gaping hole.
Just thought I'd point out that I went to Home Depot, and while they didn't have the exact part described in the first post, they had something similar.
It was in the plumbing isle, near the o-rings and other rubber parts that one would use to repair their faucets. It was a different brand (sorry I don't have the label with me), but was definately for an American Standard faucet.
The plugs themselves were nearly identical to the ones in the photo above, but were concave on the top of the plug instead of flat.
They seem to fit pretty well, although not as snug as I had hoped. They are just a little loose, but not loose enough to pop out on their own. When measured it looked like they were mabye 1/2" instead of 5/8" diameter, but there's a lip (its kind of ribbed) on it that might be 5/8ths and is probably why it's not coming out on its own. I'm thinking about wrapping a rubber band around it to make it a little more snug, but I don't think they're at risk of coming out or letting dust/mud in even if I don't.
Thanks for this idea-- it was raining the day I put them in and you can certainly see how mud and dirt would come up through them, there were already a few water streaks near the larger holes.
Old post, but good info. I plugged the 2 big holes with rubber plugs from Home Depot and filled the small ones w/silicon.
