4th Gen JAOS Battlez Springs
TOPSECRETTUNDRA
Does anyone on the forum know of anyone running these lift springs in a 4th Gen? I've searched but only found people using other JAOS products. I'm not even sure if they will work with the 4Runner but I picked up a set anyway. Also does anyone have stock springs loose that they can measure for me? JAOS claims a 2" lift from these but that is for the Hilux Surf. Thanks in advance.
Ryan
[MENTION=35890]TOPSECRETTUNDRA[/MENTION] i can't think of anyone I've ever seen running those, and what year hilux surf are they for? they also look like progressive rate coils
Those look pretty cool since they're progressive rate... I think I've seen most of the Jaos products people have installed here but I've never heard of those springs.
Let us know how they work!
Thanks guys! I''m in Japan for the next couple years so I'm stashing all the parts for my 08 while I'm here. Now I just need the shocks to complete the lift.
The paperwork says : 11.7kgf/m, 3.4kgf/m
I assume one is front and one is rear.
If this is right - 1 kg/mm = ~56 lb/in =
then it's ~655 lb/in Front ~190 lb/in Rear
That sounds about the same as OME 886 up front and FJ springs in the rear, but I have no clue how the progressive rate thing comes into play. I suppose height will change things as well...?
Here are some heights and rates of other coils if you want to try to compare heights and rates - Coil Rates
They do make 30mm lowering springs as well. I have no idea to tell but I hope these are the lift springs. The guy I bought them from had no clue about them.
