4th Gen Lighter Install?
MikesToy
Banned
Can someone post instructions how to replace the existing 12V console beside the shifter with the 12V outlet plus lighter kit? Thanks!
MikesToy said:
actually i was wondering if there is another "plug and play" thingy for the lighter underneath.
Not sure what you mean by 'another "plug and play" thingy.' There is a small wiring harness under there that you need to plug into.
Hey Mike, if you haven't installed that lighter piece yet, maybe you can save some dinero and just install a DC power receptacle in your center console storage compartment.
Since I installed one in mine, I never use the OEM one next to the gear shifter. I couldn't stand having a cord or anything sticking out of it, and I like to close that little door over it (I believe that has to be removed for the cig lighter piece to be installed). And I'm not a smoker, so I couldn't care less about having an actual cigarette lighter there.
It was pretty easy to do, but I also had my entire center console out when I installed my head unit and relocated the DAC switch/wiring to the dash, and ran the Ipod cable to the center console storage, and installed some audio/video plugs as well, again for the head unit.
Thanks AV1. Reason why i wanted the cig lighter mod is that i could use the lighter as a weapon (stinger) in case i get held-up. haha... Also, the cover door bugs the hell out of me when i charge up my cell phone. :cool:
Have any of you tapped the extra lead under the power outlet in the console, to add another power outlet. Is it a constant power or is it ignition powered. Just wondering....
I installed this hard-wired inside my console to keep all the wires nice for my GPS and XM radio. I attached it to the inside wall with Velcro and even left the coiled part of the cord so that I "could" pull it out for ease of use. Power-source is NOT constant on, so all is OFF when the key is out. Sure makes it easy to power cell phones and stuff.
8
8
Do you have a picture of what this looks like installed? I'm searching the forums for ways to have both GPS and iPhone plugged in without having cords stretched all over the place. A photo of you solution would be wonderful!
As Allegro said, it is off when the key is off. If you wanted to mod it so its on all of the time, here's the DIY Kmvreter made. http://www.toyota-4runner.org/accessories/11038-constant-12v-power-outlets.html
My solution for plugging in my GPS without having cords draped around the shift knob, was to mount the 12v outlet on the passenger side. I bought a quality all weather rubber socket from Marine West for (8?), and flush mounted it on the side. I wanted something that would clean up the interior, and this did a good job. Look all of 30 minutes to tap, splice, drill, and mount.
