4th gen seats into 3rd gen
Pate
My seats are pretty worn out and I have the option of buying a set of limited 4th gen seats, would they fit? Probably the mountimg points are not the same so i will have to modify the frame that support them, but apart from that you guys think they would fit or it would be a tight fit and maybe should get rid of center console? Anyone has done it?
I would appreciate your help guys!
Don't do it!!!!!
Will they fit?
Sort of, they will if you bent the brackets a bit and use some "persuasion" if you know what i mean.
Limited seats will be the problem, they are likely power will be the real issue. There are something like 6 wires in those seats and 3 in ours. I sold them before i even attempted to re-wire it.
brushbuny
