4th Gen - stock wheel width and offset?
RedRacer
Does anyone know the specs (width and offset) for the stock wheels on a 4th Gen LTD?
17x? +??
18x? +??
I am shopping for new wheels and this info would really help.
The 17" wheels are 7.5" wide and have a 30 mm offset.
Not sure about the 18" Limited wheels though...
Thanks for the info. Interesting because the info that I found lists the 17" wheels at 7.5" 25mm offset :confused: Still searching for info on the 18s.
I want to use an 18x8" +20mm with a 275 tire at stock ride height. Anyone know if this will work??
The stock 17" wheels are definitely 30mm offset...it's stamped into the spokes on the back of the wheel.
As for your question, send a PM to 03 Limited. He's a self proclaimed expert on aftermarket wheel fitment.
But if I were you, I'd look for a wheel with a lower numerical offset to bring the wheels out toward the edge of the wheel wells. A wider stance will give your 4Runner a mucn better look than the "tucked in" look of the stock wheels. This is a much bigger problem in '06 and newer 4Runners, due to the bigger flares around the wheel wells.
alexhales578us
