4th Gen Timing belt replacement good deal
SoCalMike
Junior Member
Just had my timing belt changed @ 88K. Indie Also suggested I do the the water punp while he was in there. Great suggestion, as the coolant was weeping out around top gasket. Glad we caught it.
Out the door for $540.00 ...FN coolant $44.00 bucks :(
Did you have to replace the entire water pump or just the gasket? I thought that expensive coolant Toyota uses was supposed to prevent problems with the water pump, gaskets, and the rest of the cooling system. :confused:
I thought the 4.0 had a chain, not a belt? I seem to recall when shopping that was one of the "plus" points of the 4th gen over the 3.4 in the 3rd gen?
mine's in the shop getting done as we speak. my cost is just about the same plus a little more for an oil change. they're going to inspect the coolant, pump, gaskets, hoses, etc to see if they need done. but they started working on it 4 hours ago and as of now, no phone calls.
edit: they're replacing my coolant and my serpentine belt as well. now i'm ready to go drive it somewhere! :D
alsayner
