4th Gen Transmission Cooler OEM and Custom
tketke
I have two transmission coolers that are no longer going to be used. I am selling an OEM setup. The cooler is pictured but will not include the mounting brackets.
I also have a larger cooler setup I will not be using. It is currently mounted on my truck but was never actually used. the caps remained on the input and outputs, so nothing ever went in or out of the cooler . I also made a custom mounting setup included with it. the cooler does not touch the ac condenser or radiator, it sits low in front of it on an aluminum bar.
I will post better pictures when I remove it. Mounting it would require just drilling two holes on a support running across the ac condenser.
Best offer on both.
