4th gen wheel offset - what will work?
jediwebdude
Will I run into issues if I go with any of these offsets: -6mm, -10mm, or -12mm? I currently have a 3-inch lift and am running BFG A/T 275/70 17 tires.
Tore up my beautiful stock rims while off-roading the last few times. Time to replace them with some black rims. Looking at KMC, SCS, and ProComp. Currently I have SpiderTrax on with my OEM rims, but will remove the SpiderTrax when I install new rims.
Your sig shows that you've already picked up a set of Pro Comps already, but in case this helps someone else along the way, our SCS Stealth 6 wheels with fit without any issues.
This is an '03 with 265/70/17 with our Stealth 6 wheels. They're 17x8.5 with -/10mm offset.
DSC_0064-1.jpg~original
DSC_0022.jpg~original
On another thread, I posted about the larger brake calipers on the 4th gen Sport Edition 4Runner limiting wheel selection. This came up because Pro Comp didn't ship my first choice because they wouldn't fit over the calipers.
As a result of the bigger brakes, the wheel options for 4th gen Sport Edition owners are limited. If SCS rims (which look very nice) will fit over the calipers, you may want to market that fact.
The Stealth 6 does indeed fit over the sport edition calipers. Thank you for bringing that up:cheers:. The pics above is an '03 that the owner upgraded with sport calipers after his stock ones started to show signs of seizing.
Giordano Schoenwetter
