4WD Multi-Mode Question
SIN-Japan
I have read through the docs I can find but have not been able to fully understand or maybe this question is not answered in the basic write up stuff of the 4WD system.
I have a 1997 Surf with the Multi-Mode 4WD system.
My question is, if I am in H2-H4 (Button Pushed) so center Diff Unlocked is my Front Diff engaged?
Example: If I put a Spartan or other Lunchbox locker in the front would it engage in AWD Mode? or only when in 4HI(L) or 4LO(L)?
Thanks for any input on this, my apologies if I missed that info in this thread:
http://www.toyota-4runner.org/3rd-g...rs-3rd-gens-transfer-case-awd-multi-mode.html
Thx.
the spartan locker would be active in awd, its not really a good setup for the front, you probably want a selectable front locker.
The fronts are a touch more fragile, and respond better to an LSD (i.e. Truetrac) than a full on locker. That's based solely what I've seen on the forums. Also, I have had a Spartan in the rear, and it was ... annoying until I got used to it. If I had to do it again, I wouldn't, but would instead hold out for a Toyota elocker retrofit. Of course this only applies to the rear.
Mike Sargent
