4wd Problem
tahoe22
I have a 2000 4Runner Ltd that now does not want to come out of 4wd. A mechanic has looked at it, and the switches are fine(will disengage if manually crossed). He has also ruled out the sensors. I'm stuck in 4 high and the dash indicator light just flashes constantly.
Any ideas?
Yeah, you can tell that it's definitely engaged. Also, if I go into 4 low, I'm stuck in 4 low until the switch is manually crossed. It will go from 2 into 4 just fine, but not out of 4wd.
ya im having a similar issue with my 4wd.goes into 4wd just fine,button stays lit,and doesnt come out unless imonkey with the lever from h2 to h1 to n a few times.dont know what the problem is
