4wd system swap
mwollman
Hello, I recently flopped my 2000 4runner on it's side and ended up buying another 98. Unfortunately the head was bad and now I'm doing the motor and tranny swap seeing as it had lower miles anyways I might as well do both.
However, we aren't sure if we'll have any issues due to the fact of the transfer case and 4wd system being different.
I was curious if it was worth just swapping the whole driveline, front and rear ends along with the transfer case and such. Also, has anyone done this and if you have how much of a pain in the ass is the wiring.
My 2000 also came with the rear locker and I believe it is geared lower as well.
With out knowing what you had and what you got, I can attest that anything is possible.
:hippie:You just have to believe.
[MENTION=25058]ChildrenOfBodom[/MENTION] has done this. maybe he can show shine some light on this subject and answer your questions. Good luck!
Well I suppose if it's possible to do the 2wd to 4wd this is basically the same without fabrication. I think we'll go for it and see how it turns out.
Singtoe has one of the best 4runners on here. He is the MAN!
We need to get together. Build a 3rd Gen with the 5.7 and blow it. Get a Merlin Crawl Box, Lock it, and run 37 on it. I believe :pray2:
Blue
leolediola
