Thanks for the responses. The 4wd light on the dash does operate and when it is on, we are definitely in 4wd and when it is off, we are definitely in 2wd. If I read the wiring diagram correctly for this transfer case, the relay is powered and operates to switch, when the it gets a ground signal from the 4wd mechanical "detection switch" on the transfer case. Power also goes to the 4wd light on the dash, which only lights, when it gets a ground signal from the "ADD position switch" on the axle disconnect mechanism. When I get the chance, I plan to run an alternate ground wire to the relay with a switch, so that if I lose 4wd again (when I need it most, of course) I can feed the relay another source of ground to see, if that make the relay work. Sure, that's the ticket. What could go wrong?
