4Wheel parts guy said G2 made by Spidertrax
HoloHolo
4Wheel Parts guy said G2 wheel spacers are made by Spidertrax. After reading threads on spacers, I couldn't find any info supporting that but G2 is also made of T-6061 aluminum. I know $20 aint a lot but if it is the same product/ quality, why not. Anyone know if this is true?
It is hubcentric and they work just fine. I have them on my truck, I picked them up from 4wheel parts as well because they were in stock and they were less $$...
I am not sure about spirdertraxx being the manufacturer but it would not surprise me since it happens all the time that companies will sell a product branded with their name but manufactured by someone else...
The only thing you should make sure is the thread pitch of the studs. I've seen some cheaper companies use 1/2"-20 studs for applications like ours. So you would end up using 12x1.5 nuts to hold the spacer to the hub and then 1/2-20 nuts to mount your wheel. Worse part about it is they come with 1/2-20 nuts so you can't even use them to mount it up.
