4x innovation sliders
wrestler157
Does anyone have pics on how they welded theirs up? It came with plates,posts,then the actual sliders. I know the order it goes together just was wondering if anyone had pics and also there is a hole in each corner of the plates is that if you want to bolt them up? And it came with some little triangle pieces ill post a pic not sure what they are for. Thanks!
The triangles are frame gussets, they attach on the top of the tube and to the scab plate and provide extra rigidity.
I believe this pic is of the 4xi sliders, but if not the principle is still the same.
4runnermarch121.jpg~original
Also two of the amounting post are longer than the others where do these ones go and why are they longer. I did get the kickout sliders if that has anything to do with it for them to go on where the kick out is?
You're going to want to cut those down to match the length of the others, or desired length. Here's a helpful thread about welding 4X sliders. http://www.toyota120.com/forum/showthread.php?t=24930 and here's some pictures I took of a friends sliders I welded on his tacoma.
Yeah the two longer tubes are just cut long to allow you to customize the placement a bit. the holes in the plates are for spot welds to add addition plate connection to the frame of the truck, you fill weld the holes in as well as run a weld bead around the perimeter of the square plate itself.
(also weld the gusset in as show in gaterose's pics)
when I installed mine, i cut the longer tubes to match the length of the remaining shorter tubes it worked out fine to mount them on parallel to the frame.
