4x4 PSA: Use it or lose it monthly reminder
Since my wife and I recently bought a vacation home near Sylva NC I don't have to depend on these reminders any more. Our driveway is gravel and steep enough that it "requires" 4wd/AWD to get up. Not really that bad but I usually use 4wd just to avoid any spinning and keep from moving any of the gravel. But I've tried it in 2wd a few times and the 4runner has no problem. Not sure if it would start moving again if I were to stop though. And since we are up there at least once a month, I have my own reminder, lol.
I do this monthly reminder on our local Facebook page.
I also add a reminder to run that generator if you have one.
NICE! that makes it easy. just remember to engage 4L and lock the center differential once a month as well. it's not so much 4H that people have issues with...it's getting into/out of 4L along with the center diff you really need to make sure to use and not lose!
Good point! I'll have to do that. Last time we were there I ended up using the center diff lock and 4 low out of necessity. Someone else who lives on our entrance road plowed the road while it was raining in preparation for some new gravel being put down. It turned the road into a 6 inch deep clay quagmire. I really got to see how well the runner does in bad conditions. I still haven't gotten all the orange clay out of the fender wells. For about a day I was starting to regret buying the house; it was so bad. But as soon as it dried out they laid the new gravel and all is great now. But you're right, and I will exercise those functions at least once a month. With this new house if my 4wd fails I won't be able to just ignore it. It'll have to be fixed pronto, cost be damned. As a side note; I was very pleased with how well the runner got through that mud at it's worst. I tell my wife it's a mountain goat, lol.
Does the use it or lose it advice also apply to full time 4WD V8 4Runners?
As in, do I need to put it in 4LO monthly, or am I fine using that system less than monthly since the truck is in 4HI all the time?
Thank to this thread for helping me get my 4low unstuck.
I doubted if just engaging and disengaging the 4low switch would work but I was wrong.
I left my new to me 06 4runner in the garage overnight with a heater in hopes to get the grease in the gears warmed up.
Tried it several times while going in and out of neutral. Then it went! At first I could hear the gears t-case gears kinda grinding a bit as if the actuator was moving slowly. After 4 or 5 more times it's engaging instantly now.
I went up a local trail in the slush and snow for a couple hours, working the 4low switch at least 2 dozen times.
Working perfectly!
Thanks again to this tread :-)
It is the transition from 4HI to 4LO that give people the most problems, then the center diff lock second.
So, to answer your question, yes it would be prudent even in a V8.
Wow! I had no idea about this! We haven't used our 4wd since moving from Colorado to California. We'll have to set a reminder to do this every 6 months from now on.
You apparently didn't read the very first post in this topic nor what it says in your owner's manual, it says to exercise the actuator once "every month" not every 6 months!
But it's your T4R do what you want to do.
Additionally ensure the vent lines are connected to your front and center actuators. Moisture seeping in the vent will ruin your actuator and day.
The front actuator quit on my off road 4R after repeated on/off cycles during a one day session, of in and out of a river valley, due to electrical continuity failure. Fortunately it failed in 4WD mode or the tow bill would have been outrageous. I purchased a NEW actuator from Toyota. The unit was defective. That issue was a royal pain in the A$$ with trouble shooting, returning the part to Toyota and dealing with a dis coordinated service manager who stuck his nose into the issue.
It is winter in my area. 4WD mode is on permanently until the ice and snow wear off the highways and is activated in the cities to navigate the ice on the roadways.
Use it or loose it OR Use it and loose it.
Can you describe what to look for or post a pic?
Here is a friendly Public Service Announcement:
Engage all your 4x4 features once a month and your truck will thank you for it by avoiding a hefty repair bill. A few minutes of free exercise every month will save you big $$$ in actuator repairs.
I've noticed a few more threads recently about 4x4 4th Gens with problems getting in or out of H4 (for the V6's), L4 or the CDL due to lack of use. The shift actuator rods seize up.
I had this same issue years ago but not as severely. I got lucky and was able to get the system to work just by using it. The more I used it the easier and faster it shifted in or out of the modes. I set a recurring reminder in my calender on the first day of every month to remember to engage the 4x4 system. I plan to bump this thread as required (plus it gives me a legit reason to be a post-whore.)
(I know this is a day early but I won't be near a computer tomorrow.)
#saveuractuator
I'm gonna be honest I don't think mine's ever been in 4LO. Uh oh.
Hi everyone! New to the 4Runner world. I picked up a 4wd v6 and reading all the posts on this forum I’m slowly thinking my issue might be a major problem lol. I got a 05 4Runner but when I put it in 4hi or 4lo none of the lights come on, I also don’t think it’s engaging at all (no clunk or jerk or anything, just feels like normal). However if I press the differential locker button, that light will turn on and it seem as if the diffs are locked.
Any suggestion on where to start? Could it be electrical? Mechanical? All of the above probably? Lol! Any help would be greatly appreciated
Any suggestion on where to start? Could it be electrical? Mechanical? All of the above probably? Lol! Any help would be greatly appreciated����
Aloha!
No response to operating the 4WD rotational switch? I'd start with electrical, and the simplest explanation would be someone disassembled the dash and neglected to put the plug back into the back of the switch. It's easy to forget one of the plugs, especially if you're in a hurry.
