4x4 Trail Rating Chart
TripleTS_T4R
Well, if this is a repeater, I am sorry. I have looked on here but didn't find a place where this was 'sticky' (hint to make it a sticky, lol) or in a thread/post. I think this will help when explaining the type of trails one may go on and have a reference. I have had some people explain the type of trails they ride and i have to bookmark in my phone just to go back and see how difficult it is that they were talking about. Needless to say, I have found a chart that takes all this research out the equation. I hope that this helps fellow 4runners when choosing your path of adventure! Ride hard and be safe!
The classes of trails below are to be considered a baseline description of an overall trail type under ideal conditions. Terrain analysis will take into account weather effects to trails and specifically note any effects that will degrade operations or require changes in operational expectations. Flatwater Overland shall rate a road or trail with the appropriate class based upon the most difficult section or obstacle encountered on the section of trail.
Class 1–Maintained unpaved road. Firm, dry improved surface, or less than 3 in. water crossing depth. Only gentle grades present similar to highway construction, 2WD under all conditions except snow. No width or trailer towing problems, at least two vehicles wide. This is a typical maintained gravel country road.
Class 2– Semi-maintained dirt road. Dry, or up to 3 in. water crossing depth; some minor ruts; slight grades up to 15 degrees; 2WD under most conditions. Rain or snow may make 4WD necessary. Road is usually one and a half to two vehicles wide to allow for passing. Road is acceptable for most types of trailers. This is typical of moderate use roads in backcountry or agricultural areas with at least annual maintenance of the roadbed.
Class 3– Unmaintained dirt road. Ruts, washes, or gulches may be present; water crossings up to 6 inches in depth possible with a firm bottom; passable mud or sand sections may be present. Grades up to 20 degrees may be encountered. Small rocks or holes may be frequent. Rock or dirt shelves will not exceed 6 inches in height. 4WD recommended but 2WD possible under good conditions and with adequate ground clearance and skill. No width problems for any typical passenger vehicles, and vehicle passing spots frequently available if less than two vehicles wide. Towing of a standard production trailer may become difficult. This is typical of a regularly traveled backcountry road that has not seen maintenance in several years. This is the last class of trail that can be traversed by a factory supplied all-wheel-drive car or crossover vehicle without damage.
Class 4– Rutted and/or rocky backcountry trail. Rock shelves or stair steps not exceeding 8 inches in height may be present, and rocks to 8 inch caliper may be encountered. Any water crossings encountered will usually be less than axle hub deep with a firm bottom. Passable mud or sand may be encountered, with moderate grades that may exceed 20 deg. Side hill camber may be moderate up to 15 deg. 4WD will be recommended under most conditions to increase control. No width problems, with vehicle passing spots frequently available if less than two vehicles wide. Only short wheelbase trailers rated for off pavement use should be towed here. This situation will be typical of backcountry forest or desert trails that see light but regular travel and only see enough maintenance to remain passable. This route should passable with any stock traditional 4x4 SUV or pickup truck.
Class 5– Rutted and/or rocky trail. Rock shelves or stair steps not exceeding 12 inches in height may be present; rocks less than 12 inch caliper may be encountered; water crossings up to 12 inch depth with possible currents but a solid bottom may be encountered. Passable mud or sand sections may be encountered. Moderate grades exceeding 20 degrees may be present with up to 6 inch deep holes present; side hill camber expected to be up to 20 degrees. 4WD required under most conditions with no vehicle width problems. This is the most difficult trail that should be attempted with a stock full-sized 4x4 or with a standard production short wheelbase trailer unless specifically rated for off highway use. Trail clearing and building may be necessary for stock vehicles to pass undamaged and brush may be an issue for full sized vehicles.
Class 6– Very rocky and rough trail. Frequent rocks encountered and may exceed 12 inch caliper; water crossings may exceed axle hub depth with strong currents. Rock or dirt shelves and stair steps may be encountered not exceeding 16 inches in height; mud sections may require checking before proceeding, sand may be loose and deep with dunes. Moderate grades exceeding 20 degrees encountered, and side hill camber may approach 30 degrees. 4WD is necessary with a stock high-clearance vehicle, and second attempts may be needed on obstacles with stock vehicles and/or minimal off road driving experience. Vehicles with locking differentials should not encounter significant trouble. Caution may be required with wider full size vehicles due to obstacle size and trail width restrictions. Driver having experience with off road 4x4 driving techniques will prevent vehicle damage; vehicle modifications with gearing, traction aids, and suspension will also be helpful. This is the last class of trail that an inexperienced driver with a stock 4x4 vehicle should attempt and the last class of trail a stock vehicle with an experienced driver can expect to traverse without damage. Only specialty off highway trailers with oversize tires and extended suspensions should be towed. Trail clearing and building may be necessary with heavy brush possible.
Class 7– Technical backcountry trail. Rocks will be encountered frequently with a 12 inch caliper and some may exceed vehicle hub height. Holes and washouts are frequent or up to 20 inches in depth. Rock shelves and/or stair steps may be encountered to 24 inches in height and in sequence. Eight inch deep mud may be present with ruts and may also be present on uphill sections. Sand encountered will be deep, loose, and large dunes are likely. Grades encountered to 30 degrees and side hill camber encountered to 30 degrees. Water crossings to 24 inches deep encountered, and may have strong currents with soft bottoms. 1 ½ vehicles wide maximum; 4WD required at all times; driver experience with technical 4x4 trails necessary and vehicle modifications in suspension, traction, and gearing extremely helpful. Multiple recovery operations possible and may require winching. This is the highest class of backcountry trail that the driver of a typical overland modified vehicle can expect to traverse undamaged and the highest class of trail a typical stock 4x4 can be expected to traverse. Custom or specialty short wheelbase, light weight, off highway trailers with large tires and custom suspensions are towable, but will likely experience damage or rollover. Trail repair or building may be necessary to traverse and heavy brush is likely.
Class 8– Technical trail with heavy rock and/or severe obstacles. Rocks exceeding hub height will be frequent with washouts and holes also exceeding hub height. Rock or dirt shelves or stair steps exceeding 24 inches in height are likely to be encountered. Deep mud and/or uphill mud sections may be present. Landscape scale dune areas and soft, deep sand present. Steep grades exceeding 30 degrees may be encountered that can also be loose and rocky. Water crossings may exceed 30 in. depth and/or contain currents and a soft bottom. Side hill camber to 30 degrees will likely be encountered on the trail, and trail will be no more than 1 vehicle wide. Frequent recovery operations requiring winching probable, and vehicle damage probable even with an experienced driver. Vehicle modifications are necessary and may be required; trail will not be passable by most stock vehicles under any conditions. Towing of even specially constructed overland trailers not recommended at this difficulty and beyond. Trail building will likely be necessary in order to traverse in modified 4x4s with likely damaging vegetation along the trail.
Class 9– Extreme technical trail recommended for specialty off road vehicles only. Severe rock over 20 inches caliper size and frequent deep holes over 24 inches in depth common on the trail. Rock or dirt shelves and/or stair steps over 36 inches high present. Mud bog conditions (long, deep, no firm bottom) requiring winching may be present. Water crossings over 30 inch depth with strong currents and a soft bottom may be present. Steep grades over 30 degrees and side hill camber over 30 degrees present on the trail and are likely to be loose and rocky. Trail building and repair probable for passage of even highly modified production 4x4s. Not passable by stock vehicles. Driver experience essential to safely traverse the trail. Frequent recovery actions including winching are to be expected. Driver should expect vehicle body damage, mechanical breakdown, probable rollover conditions, and possible personal injury. Extreme caution recommended and should not be attempted in anything but ideal conditions by experienced drivers in heavily modified vehicles.
Class 10– Severe conditions. Extreme caution recommended. Impassable by stock vehicles and most modified production vehicles, winching will be required to traverse under any conditions, and trail building will be necessary. Trail may be impassable under anything but ideal conditions in any type vehicle. Vehicle damage is probable, personal injury is likely, and extreme caution is necessary. This type of trail will not be passable by an overland prepared vehicle without extreme trail construction and is the realm of the purpose-built sport 4x4 buggy.
Hope this helps referenced from -- flatwater-overland
I saw a similar rating system on some 4x4website or other some time back. From what I recall the ratings look, if not identicle, at least close enough for government work ;).
Is their no universal, definitive trail rating system out there, like their is for rock climbing (w/ hands and feet) or white water rafting, or skiing? Or is this, and other simillar ratings it? Either way, good enough. After all, where's the fun if you know exactly what you're in for?
Oh, and +1 for Stickiedom. Lets make this the Final, Universal, Definitive Standard. The 4x4 FUDS (tm), if you will.
Man, that list is way to long. Club down in San Diego called justruns.com keep it simple. Trail Difficulty Ratings ? JustRuns 4 Wheel Drive Club
The JustRuns Difficulty Rating System Does Not Include a “FEAR FACTOR”. A trail may be very ‘Scary” for some people but have a “Near Stock” Rating of 1 or 2.
Keep in mind that the equipment below is RECOMMENDED in addition to the REQUIRED EQUIPMENT for all runs.
In addition to the equipment below, from time to time a Run Leader may REQUIRE Specific or SPECIAL EQUIPMENT.
If Special Equipment is REQUIRED the Run Leader will specify it in the Run Announcement.
A trail can change as the result of weather or usage so any rating is just an estimate based on the Leader’s judgment. We base ratings on what equipment a driver with average experience needs to negotiate a trail without expecting equipment damage. Since individual ratings are only an “Estimate”, there is no guarantee that they are accurate.
The list below uses the word “Required” for some items. What is meant by that word is we feel the listed items are needed for inexperienced drivers to successfully negotiate the trail with good confidence that there will be no vehicle damage and the vehicle will not require towing help.
Two Door vs. Four Door Jeeps.
Because of the extra length use as a “Rule of Thumb” that a Four Door Jeep needs tires approximately 2 inches taller than a Two Do to be equal in many height clearance situations.
1 . Near Stock Front & Rear Tow Attachments. And Required Equipment
1+ Near Stock Above plus AT or MT tires suggested, Appropriate lift for tire size.
2 . Near Stock Above plus, Min 31” tires for a 2 Dr. or 33′ for a 4 Dr. Required, 33″ suggested, . Anti-Sway 3 Bar Disconnect Recommended.
2+ Slightly Modified Above plus, 32” Required. 33” Suggested, 35″ suggested for long wheel base. 1 TAD suggested (Traction Aiding Device). Anti-Sway Bar disconnect required.
3- Modified Above plus Min. 32′ tires Required, 33 Recommended, 35″ for long wheelbase., 1 TAD Appropriate lift for tire size.
3 . Modified Above plus, 1 TAD Required (Traction Aiding Device), 32” tires REQUIRED, 33″ strongly suggested. 35″ strongly suggested if long wheelbase.,
3+ Modified Above plus, 33″ tires Required, 35″ Required for long wheelbase 1 TAD Required, 2 TADs Suggested. Winch suggested.
4 Highly Modified Above plus, 2 TADs Required , 35″ strongly suggested for short wheelbase. , (37″ Required for Long Wheel Base.) Winch strongly suggested.
4+ Highly Modified Above plus, , 35”or 37″ if 4 dr., or TALLER Required, Winch Required. Experienced Drivers Only.
Expect some vehicle damage.
5 Highly Modified Highest Difficulty Rating Our Group Attempts.
I don’t care what you have, you are likely to break Or damage SOMETHING!
Note: A Traction Aiding Device (TAD) may be any type including:
A full time or Selectable locker, limited slip (posi), Tru-trac, ARB, OX Lock or any other mechanism that prevents wheel spin when one wheel loses traction.
NOTE:
Trails more difficult than 5 require highly skilled Drivers and Highly Customized Vehicles or the ability to laugh at vehicle damage and possible personal injury.
Trail Ratings are very subjective and the difficulty of a trail can change from time to time due to many factors including weather, erosion, amount of use as well as modifications to the trail by people. We try to accurately describe the difficulty of a trail but sometimes we are surprised. Drivers should always be aware of their skill limitations and the limitations of their equipment. Keep in mind that vehicle damage or injury can occur at any time on any trail. Whenever a driver feels in danger he/she should immediately ask for help. It is always easier to put a strap on a vehicle or guide a vehicle over a dangerous obstacle than to repair a vehicle that was damaged unnecessarily. There is no shame in asking for help.
after glancing over those above, i really like the system used at my local OHV area. Its practically identical to ski resorts and i feel like i know exactly what to expect, or (run away from) when i see the sign at the trailhead and knowing nothing else about the trail. Of course conditions can vary by weather, overuse, erosion, etc but i know what to expect.
Heres what a trail sign looks like:
link to trail map:
http://www.oregon.gov/ODF/Documents/Recreation/TillamookOHVGuide2014.pdf
The biggest problem is after the first post, the rest are all subjective. It is exactly like trail ratings at ski areas. A good example a Green run at Jackson Hole/Snowbird/Squaw/Mad River could be a Blue or Black at some Mom & Pop hill.
The first post was pretty decent, mostly describing the actual trail conditions to expect and not necessarily based on the vehicle or equipment you need to do it in. Anyone with half a wit and some real experience would know what they need.
The subsequent posts after that fall into the subjective range. For example define "Highly modified". To me is an application specific vehicle, to someone else it may be they just dumped 15 grand into their truck buying the latest do-dads/upgraded suspension/light armor/ect. They could certainly think their vehicle is highly modified. Another, what's a long wheelbase? A CJ5 versus a JK or a Tacoma? Subjective is dangerous in an era when people think the can buy experience vs actually knowing their limitations.
Any kind of ratings can be good, they are much better when they meet a universal standard. There is no such thing as "too much information" there is a problem with too little.
A blue run at Taos Ski Valley is not the same as a blue run at other ski resorts.
You will know what I am talking about by only experiencing it.
Same with trail ratings. The ratings will always be subjective, while still being a good measuring tool.
It is still always the same mantra - go at your own risk.
link to trail map:
this is what I am used to as well. green, blue, black. I have also seen orange, and red, maybe yellow. but those were on dirt bike trails.
ive never seen a vehicle trail above a single black. though I have heard of few pretty bad trails, I would expect/hope they are rated higher than black. as I have been on a few black trails, and they really weren't that bad.
I think part of the problem with the trail ratings, is they don't get updated often, or at all. I know of a green dot trail that I found years ago. I was able to run it with a stock rig, on 235/75/15 tires, and complete 99% of the trail. taking the bypass around only ONE very large mud hole.
that same trail is still a green dot, but you will struggle to get through most of it on 42's, locked front and rear.
erinobr2000
