4xInnovations turn signal help please
Mados
I've searched for a little bit, but haven't really found what I need. Can someone tell me what the trick is for the turn signals that come with the 4x bumper. I've got them working, but they are blinking fast like a bulb is out.
I don't have the bumper but if it came with LEDs then you need an electronic flasher to remedy the situation.
Reverse/switch the 2 power wires & see if it works normal.
The lower resistance of the LEDs messes with your flasher relay. You need the "Tridon EP35 flasher relay" to fix it. Can be purchased at most auto parts stores
119_1152.jpg~original
I live with the hyper flash and now I feel regular blinkers are slow.
Like stated above you can swap the flasher unit. If you install rear led tail lights I heard the flasher wont work and you need load resistors to remedy the issue.
Thanks for the info guys. It would have been nice if 4x would have disclosed that information that I would need a new relay. Think I will see how I feel about the hyper flashers for now.
Mike Sargent
