5th Gen 2014+ Spark Plug Removal (Air Injection Pump)
I looked for a 2014+ Spark Plug tutorial... Antman's daughter is AWESOME.. but 2014+ has the Air Injection pump all in the way. So I took some pics while I did my plug swap today. Hope this helps anyone wanting to tackle it themselves. I will go over what you need to do to get to the spark plugs.. but refer to [MENTION=65614]Antman[/MENTION] daughter How-to for the spark plug removal!
Tools you will need.
12MM Deep Socket
10MM Deep Socket
Various extensions
Ratchet
Small flat head screwdriver
Pliers
Now, first remove the engine cover (Pull Up and then Toward you)
You need to remove the Intake hoses.
The Circles identify 10mm Bolt to remove, as-well as the screw on the clamps.
The Triangle indicates a small vacuum hose (I already removed prior to the picture) Just pull on the hose and it will pop off.
The Diamond has wire loom that is held down by a small push in retainer. Take your pliers and squeeze underneath while you pull up on the wire loom. It should pop right up and out.
The Square has some sort of hose. Now, you can undo the clamp.. but if you just pull, that whole thing will pop out of the intake hose.
The Polygon is a plug you need to remove. You may need to use the screwdriver to get the retainer to be able to remove the plug. BECAREFUL.. ALL plastic plugs are brittle. They have been sitting next to the engine for X amount of miles. So use finesse when removing any electrical plugs.
The Square has a wire loom that is secured to the airbox by a simple clamp. Take your small flathead screw driver and push the retainer away, you should be able to open it up and pull the wire out.
The Diamond is the wire loom you have already removed.
PASSENGER SIDE
Unplg the connection in the Oval. Again, BECAREFUL as they are brittle.
The Squares identify the three 12MM nuts holding the Air unit. Use caution when done loosening the nuts.. they can drop onto your skid plate. Take extra time now to secure the nuts... or you will take EXTRA time removing skid plate to retrieve them!
At your exhaust manifold, there is two 10MM nuts in the Cirlces Use caution again.. as the above applies.
Once the nuts are removed, you can pull up on the unit and move it out of the way to get to the Spark Plugs. You will have an opening into your Exhaust Headers... I covered this with tape, dont want any foreign objects falling into the headers.
DRIVERS SIDE
The Square identifies the plug you need to disconect. Remove the clamp and pull the hose away.
The Circles identify the three 12MM nuts holding the unit in place.
The Circles are the two 10MM nuts holding the unit to the exhaust manifold. You can now move the unit out of the way. Again, cover the exhaust opening.
When you remove the Air unit, there is a hose that runs the front of the engine. This hose is just held in place by simple U clamps. Just pull the hose out and you can set the Air unit on the Intake Manifold.
To make removal of the rear Passenger Spark Plug easier, I removed the 10MM bolt holding the heater hoses to the intake manifold. The Circle shows the approximate location.
Hope this helps!
I am around 95,000 miles. I didnt "have" to replace them just yet. But, I was going to clean my Throttle Body. I usually do maintenance items before the manufacture time frame.
Damn that's a lot of miles in a short time! I bought my 2016 brand new 1/28/2017 and as of today, I have 9,300 miles on it lol. How did your plugs look when removed?
12MM Deep Socket
10MM Deep Socket
Various extensions
Ratchet
Pliers
JgsALwQgRIM_OczDMqXMotU66FYzpvMQJT1WQuiULhXWm3ZZIrP-k-ZDet-4-oi45m0ITzZsjbqZthswn5DBh7JwV4qjY-if9f3dvk_wP_OVgBa4e3Cq_G7zob2eo5Q5b6R2ITUKoACzKV_wHl9aQjhYNyNKFBMlRtLZOi3w_sRZUwvx7CFCKpH95UeSeFM4iXKGhpMT300npfrcyIyf-OQqfLehWxdJKLFgLp-Y81JBvu6CXtjszOz9exp1z2fzYSrTw6wNRXYabQmRHYs4KBWUrE3r754BXx2B8cw10KecFmSv2WjJRxiCvBiVElF_wTwTBkromrOavBAVRtRI2f90qdx9xpaNJ5cysUnBOmFAanmt_GXd5IfbgWuQHZmh1gVK3PRRKvDryiHMwzo9zSqIiOD7Kdj6RPvXVve9W4myjIF7gMWyPWlsbIvBUvBLSUUm52jbVn4M2hH_dCOGJSt0L5CXCPD4C1GhwHmxwUD3zM7PtMbyJFrPMZCwFl77Sd1PEgOwShZE0UbYksCdXuFiPVutPEI4EdLTgHruJIFKtofw1ujryZ75u-EZIptlXHHoPo8z2rDSVJ09LBc3wCzmfyqqeuwCQ_OCfPo=w720-h959-no
ncQEv3LXkuqkvUYezx9aT-1OkTIpjxYYv4PkzzBGXLYWO__znqHjqdfZNgIJJxZ2CX9cHD8xZsFbLvYKCM7T96a49A8GEqHov5YBrzphdoJnLpqp45ovpmqcxTrRPluV3TCmlrQRiSKiRR_Y6U6MbIFfHURHUKh7uHrhCoSfusoo8JtzTCpAnzBwUWHGJ8pNqDy_uTT_rZbhpepRvl4-3pMjjwUVNP57dNRbtHfSqnWyRk3ze9doFDv_aCHMCZGZYjAkghqPGOV41Ymp8fcAYVOeiK8jqj0xzB3fMuWS-H-27M_MT15mQ2j2LINeM_FZ0AqKSTA6CGTCq21dgCvyBFTojYLTn2w9sHqJrp0v2QP2xCD95yM3idHpi-m1R8ckVY1t37KxaZPmQkeuMz1fEiC90kZYftHx5-CV2Zqr_jr7s_IiqJ0yhMbHAyxtsiYFrT1mD1X6OgM4fsdvWFoN33m1YPC3H-ydnf5zquPuFaDdO_anj-xRYomIWpvQ1fUqQKhZa6lOzOswUmOScuN1b-ih4F-FYKbxxx3LLC_Adds-QXwv-WzR0PSH1p7RjcSCE1eBKawPp0eBzPjx1OtwvPpC1NE_ysOF-8hKLhY=w720-h959-no
4zts47P0kH3LGUvG5Q1DcWMmuXh2Ildd57o8fIDrPEtgKF5uZPuE1mtxhFGQD5mwV7vQZOQnDdN4M4fDYAFhTTQYBvRhBkeATCxMgU31AXxXksOm5u7kdFHKUQ7u8SmyMPiI0fd_H4BYRzuB3BRQXsxFavj7QevtS02Qt5AfHLAKqeOC7WZB2DJHTz6RhxUnlVaDRNOR5cwrFkmwqdT1NXI9CWjnq04AHiUq2I6olrHZNkpHTFQRxLSwSNgK9qSncZW1HYLS0x2bUKL1LmHrp7ttaViQC2ThpB8_hixMFeyZUqBw9U7LskkbVX3bDCv4sZ5typaQJgndv7fZoad5htSyJbQkquUBp9GJAEwM_pT8NgP5E1fqzVGNYkdMz78uorGyp3Ko2vHXrirOk_v4jjKQRxrevftmWydFHyxuxjoOSU51ybe2_OgPXOSNjDNpokqg4ib5xaVDrlK6ZfrFhoY8KV4fsQ7qF9ghtlL29UkhW1k9p-zTI6mJLzoJj-z3IpnfaMfG_dhC31s0zIX_TGAZz6zHhIa2jo7p-K2wHWPvwKacQjJPfVpuKOgwR4Ya5dn9icaQa5rsZG98rsoGHiWMuwoV3cJs0LSqPfo=w720-h959-no
PASSENGER SIDE
NflA03OiBTDiCeVJxt_D-IRQTI6pygLK2rMPoPissSDkEvhY3CnSo1aLYnYD1bxAvArMZ67s2Ykmpkn3nZxp3aMWjhfqsltlNCYQMLeTTyBoaj9tu5qr6Ayn2_z7Yww_nkK1-kbiAYtMu9imqIC2XFABQKmpdJvIu5R3y7muILGIoTSeh9to1lYhblPRp_itZMJaj4DH4VlhKqwAb50xfiQmMd1_2OzqBalGYvihz2-lFl7slYyHklW8jHJqndlIj0YDD8HLCsLrYcgYajNVy5BzBNFRKplNw7Zb5jv63IaZUzLm-jkAvcNh1Ti2fIugvqC4-lYalMNKtGmvvdYLpRQtfTxPWdndVlwq75Z4GLsoj-GPlTRBRjdeMqXC73XQxWCPo1YbDpg4_Xd1wJsc6NQ6CcQ3t0DGP1-ESe0i5kjo7kWVrPTU3ZK5XWKODE5Cz-AQUKfXSTgWHnB93klENubQX7V3ijjAdXiEcO1RHPrXspkuMMGVdMZyNvuHJgxIAYG9i0rM0_G4AkuQaZxoQHzkIM6WG-nOJAxgn0ALFyVmjzjGIGt4ZFm3H2ASfrcjMKVsg2CT_saIploh1OjbUW_X3-2k4NlrPupT1_k=w720-h959-no
p6y1DhOB8pNBHT_KGP6apOamoN0gFSpykvjt4XVHoxYhbzBOxmwTyRNVIXs1GnrH57W4G-hYUn_tgUyP5DWM-GcwW2ZlPB_v8X5lWdOdyipXEgUwmjWuYdKxt5QNNoyWMgMbiw4BBkX_0X5rMk2rZgOMdIonhzqHKCoy9mYwMnpRauA7A6x5r0zmtdecgi3aZHM4y9ZNwVdBxCrrPmz1N0cfgwNraQOE61kPwFkCf169aCduqNDTpWZwb1Dg2OPnNB9w86Th3bgqsgXrCC6Nc0zxwVbtTtYjI4tGcjtu3XXTFcuD9Hz8Kk5oxINFvi60g6d4MdwTrRUN_OfCtxRQrKXjLwYUjYSReulHZYCrb0E-f9Q2g8lcrsMvcBT8omf-w_ctP6ucKb_GFPlzVp-6ButeRrhvSM_yIr90-Xu9FCUfyYBvHywxYMcSx1BDppfhdwEI-6413kdPUpznLPDSwm-mHvKoHQ_KYdtG3sCugPjOozZn9ZhEs5-leqxSzUkCBBuwqUMsk5CfqP0Y3ywtN1cXkkyYoZ66-_KabHBoW7pVqeLPX3DnDAnBX9ScIchoN9w7qkk6xkWYzbpXLubM-fWu_E6mhWbljmSDyNE=w720-h959-no
DRIVERS SIDE
4r6rwaKoq8Vg4idiJbpU5ol6Fva7ckwCBmTX3r22yBi9q281pd9iRz6cNr6vuxqi3mNIINRvQqus1bqE1kxM3hkgUd_-FE32Up-NJSdlITSOT69l_pERrJhsCwNgTUsT0gVs-vBLdOJFsj2gIgSidin727f_yaDfmFWspI2zVM4r2ItGuTVp1e3mVwI6NnOMFqvmNbvCqZ0yT86RSuUFZBbk4zGvOoI3w94TfsIfyStfzLvolaLFoB9gCSAd0Okchr1-aClflJsVZCqarqyX6f5K1F3uks7XtSS1waKYYn5hY0RxY7-NkxKy_h2-e1XILyL0dk5JqUQICJbn1m4FxGHZZptx9VKyyXNVbimxziDj4yBT7_PyfrIZmTv6XuXx48a_8a2hR3R6ac_vCYbB-qi3_98hMtbZeaJN8yJLQ-0DiS2pREQOp4Kpbl491DYivCamOTFBpvy1WfHCP48PG_1SxusGVvPq99htV1ctsMiCJ8PJIG441mLCW2RIDC2Z6Izyl8zi0CchIfeqgsTKDA7_kyyRukkUaschQPL8039IChF__P1ENoeY1l74BJWAhmgl5lzuVyR7XF2upRuV-GLarR6GtxFSFhDGMBU=w1279-h960-no
mcROvaUYCAdKoFZuyMalXMHUOUfq7gVppXScm3oXi7Hayq_Wtla-x5dIcBN5zhb25CAfyfd3gPMC77Gzkkcsif8AtjGyIYewrPcQ8T6I-QdebCQbsZX58wcmvZN4KV2FZivy4eRD5tfywEjP1-Zp0ZoYdNXCXoSiztTM00hl0I4FakX07WQS0ExgcZQmTbZ7X3C-BvfpnEC7O6VWao3bHFCItWV5GO6tjSg8GDT9qBB3oUvxypdLlpwPBGpvdSGccT1sUk3KVe58pgeSoxbxawpwXHJmDszhqUaYewEPaecbp1MDHvAqFD0KftuTSAEt7DDToYp1v8gRFxGKJ7kzPp4XhUz0zmM3NV9zWv0NBuGCbBlFnMzwR-Qvktlvi1LeHwvbdxrZikYhOOcipzTv2If1HOwUabu81tLNVop5m2LXj29mxdYwUwNp1vawvA2Wn8_35kgg3THadNEEaXyt87Vvmmvg96xmMh99mhx1jhOnGKaXL9esQCXXlSAa7IGdbsa3CSaep1FGIOk5-Yb9Tt38PTj5-S48mjVhg4F86vc5KKx30obe1Ppi6OVQiQZ6uIcn_prpeGr-GodbMg7KjwNOM7tg36PUSFgDiiE=w1279-h960-no
XlvZWvZQ34sv1AIinEAvvxe22IwVOvMU2D2sl5CMGV0JpH8atsVmXfyy3cFUmGZQNtHnZfDS_HVQCRp6YouxiAk2bx-dD_qF74MjTCzsdqJnhnQbbq9P9j-9Gbl_yLxOnthHnURkSDB1gjX8TIBKVT9G4RMOLAR19VLt4_B3ZqAMx3By8xgO__gkPLnazmYj6cxxzAOqtH3X1Kmubj6I8RbsQ44SzCZOXT_O2-wES_-ulOJTlK3-dunDsaOkpPim87ichQXSqOOk6fA9Atuco6ogsipc9-Yxz2cKy3fV5_gQYLgNCpYtgdwBXJlImTvNC5_EXNJG_A1vRNV_xk-_wrUgFmeYUBAKglokhODeYZ4xnSOtSiKKmGhgQtIT1evDG61Ai551b8N0oF-k8bwgjDVkCCW9O8SyKQX3FDzuiy_UuLsDOJjPpOCbSITjCGkHpGepykqqVUJuComegYvgIgUJAoK93cRwu5SSxKanrMkzUOInQTOFaJ8Cj1IFvlI78jAWyDo2i658j0mm1TYe_HS2Eyk1cuGDH1PnqLcCDkNE2xCLjdhQvA7XeJeuyQPqxV7eqJVHVygqwSH-Ws06zfLpTJwRqouowCPE23E=w843-h959-no
Hope this helps!
Nooooo. :sobbing:
Pictures are gone.
Thanks for taking the time to do this.
Just did this job on my wife's 2014 because she hit the 120K mile mark. Word of caution for those with big hands. The electrical plugs on the harness merely have the wires poked in and held in place by some soft plastic rubber grommet. With big hands, it is very easy to dislodge a wire from the back of the Cam Position Sensor Plug or the Air Valve Solenoid plug on the driver's side. I managed to do that to both. IMO those wires should be crimped into place in the plug. I managed to stab the wire from the Air Valve Solenoid back in. For the Cam Position Sensor, I lost one of the rubber grommets and had to buy a Dorman replacement/repair plug from RockAuto.com. None of the repairs are hard, but it's annoying and completely avoidable with a better design.
Hopefully the pics come up now... Completely forgot about this thread. I just rolled 160,000 miles.. Think I will swap the plugs out while I am replacing the front axles.
Thanks for sharing this ... super helpful.
I have a 2014 and will attack this in April.
How many of you think the dealer would actually replace the plug behind the "air injector pump"
My guess is it will not get done!
I can guarantee they will charge book time for it!! LOL.. dealer called me yesterday "really" wanting to get the recalls done on my truck.
Thanks for the detailed info and pictures. The one thing I’ve been trying to ascertain before doing this job is whether moving the air injection pumps out of the way disturbs any gaskets that need to be replaced?
uthanacha
