5th Gen 4R Compared to the 2022 Explorer/Aviator - 4R 6th Gen is Here
The Explorer was FWD until just recently (2011-2019) but the Aviator was never FWD.
Thats true. This latest generation is a lot better than the previous in many ways. I took an Aviator on a business trip when I worked for Ford. It was a vehicle by itself not a reskinned something. I didn' t really care much for it.
Do you think you can tell the difference between FWD and RWD biased crossovers? Pray tell, what is it that you think makes the RWD bias better?
I've already given you a lesson on load distribution and why solid rear axles work better for load on uneven surfaces. Not sure we need to cover it again. You don't go off road. So it's not meaningful for you. That's okay. But you bought the wrong car.
4Runner gvwr is 6,300lbs Max. Again you bought the wrong car.
Do you not understand how important GRWR is?
Your so called " lesson" and "teaching" about sold axles be superior to independent was at the level of a high schooler. "Clownish pontification" is a better way to describe it. You couldn't do the math. I gave you direction on what needed to be done.
I bought a 4Runner in 2020. Now there are now a lot better options. The 5th Gen is severely lacking especially at the prices they are asking. The 6th Gen better be a whole lot better than the current Explorer/Aviator. Thats the point of this thread.
I guess I don't understand how you MUST have 6,500 gvwr but also bought a SUV with a lower gvwr. Help me understand that.
I did my best to simplify the math on sold axle load distribution so you could understand it. And explained it in plain terms. I don't think you did any math. We can go review if you'd like.
Solid Front Axle Fascination (SFAF): Help Me Understand
You want a car with big tires, you got a truck with extra seats. You bought the wrong car. That's okay. Resale is good. There's a billion crossovers to choose from. They have everything you're looking for in a car and none of the truck utility you don't like. Seems like an easy problem to solve.
In other news - did everyone know that Lincoln was still selling cars? I haven't seen a new Lincoln in a decade. Or at least not one I recognized as a new Lincoln. I kinda assumed they can closed shop.
My buddy tows an Rpod with their expedition EB and it overheats pretty regularly on the hills in Utah in the summer. Engine derates and it loses power. Not enough cooling capacity. I'm not sure if the smaller SUVs with the EB engines have the same issues. Otherwise he generally likes it as a people mover. But not a good tow vehicle.
They don't "overheat" and haven't done so in decades. You can run them empty of coolant and not damage the engines. Ive done trailer tow cycles fully loaded at 140° F (the limit of the equipment at the time at Ford) for F350's for Middle East Customers. No "overheating" and didn't derate enough to not successfully compete the cycle. I'm not sure it even derated. It did however pass the test.
Sure thing. We all believe you.
Why does the Ecoboost even have a cooling system? Apparently according to the expert it doesn't need one right?
Also, what does the "Engine Overtemp" warning mean on the dash? I assumed it meant over temperature. But since we now know that it doesn't go over temperature I'm kinda at a loss for what that means. Can you help?
This one:
Edit: now the second picture is even more confusing. The new warning says over temperature in full words. But we know that can't happen. So I assume it's a very elaborate practical joke from Ford and should be ignored?
There is no excuse not to have 4 wheel independent suspension on a truck with only a 5000 pound trailer rating. Especially if it costs $50k like some 4R's do. Regardless of what some people may think here it is the better system for off-roading.
I would love to be educated on the above point. Can you please tell us how a fully independent suspension is a superior solution for most off-road driving? I would love to hear your experiences with that.
There's a guy on another board I belong to, who has an Ecoboost F-150, who can't seem to stop complaining that his Ecoboost can't pull the interstate passes in Utah, on a hot summer day, without overheating. That's apparently towing far less than the truck is rated for...
I'm sure he doesn't know what he's talking about ether.
TFL experienced the same thing with their Powerboost F-150.
But to be fair their Silverado test vehicle also cooked the transmission fluid when towing at altitude, also while towing far less weight than it was 'Rated' for.
I'm not sure who you think you are enlightening with your 'insights'. Go buy your Explorer or Aviator already.
Huh. If I were to go to a Ford dealership, only thing I would be looking at is a Bronco Squatch. None* of that cuckhold shit you mentioned matters to me. Obviously you should have purchased a Highlander or Rav4.
I want to know about diff lockers, gear options, wheel travel, RTI scores, skid plates, clearance angles, sway bar disconnects, transfer case gearing, tires
*Except engine, the T4r motor is reliable but pathetically underpowered by modern standards.
Put a Magnuson supercharger on mine , seems to do just fine, oh and F Ford, I was happy when the wife got rid of her Explorer.
The Subaru ascent has a GVWR of 6001. Is that close enough to your mandatory GVWR? It has everything that a 4runner lacks and lacks everything that makes a 4runner a solid choice for some people.
Some highlights from your list above include:
Nice seats [emoji736]
Nice colors [emoji736]
Sent from my HD1925 using Tapatalk
My sister has one. Very nice minivan without a sliding rear door. It's deceptively huge! Like 15" longer than a 4Runner. When parked side by side it makes the 4Runner look small.
This one:
Even more interesting.. in both of these pictures the coolant and oil temp gages are pegged to the cold side.
OP, serious question, have you looked into selling your 4runner to move to the Explorer or otherwise?
Sometimes the sensors read zero when they go past a max point. I did notice that to though. Seems like it's common that the gauge goes to zero when they over heat.
I misread your second part. I have not shopped for an explorer. Lol. I bought an f250 powerstroke in January. Sold it in November. I'm probably done with Fords for a while again. Every decade or so I forget and get another lesson in domestic truck reliability. I did make some $ on the truck even after taxes and all the costs were added in I was about $5k net positive. Crazy truck market.
This guy is still shitposting? I haven't been active for a little over a year and last time I engaged with this guy, he was a new member to this forum if my memory serves me correctly. Yikes.
This is comparing apples to oranges. Specs aside at least the 4Runner doesn’t look like ass.
^^^This… This entire statement was the very thought I had, going all the way back to the silly solid front axel fascination thread and ALL the ways ‘ole Rich was schooled, lol.
I recently went to a couple Ford dealerships and Lincoln dealerships to look at the Explorer and the Aviator. I was really impressed….
The 5th Gen…
So in other words - you had absolutely no idea what you were doing when you bought your 4Runner.
Happens all the time - in 2012 I bought my first sports car…after a month I realized that it only had two seats and the Ford Fusion came as a 5 seater which was more practical.
I still haven’t sold that sports car but I complain a lot about it’s missing seats and features.
Yet, you bought a '20 4runner... I would think you would know exactly why people buy the 4runner. I could have bought whatever I wanted even at higher price range (x5, Q7, Cayenne) or any of the American options in the 50k price range.
Yet, I bought my '21 4runner fully aware of it's outdated drivetrain and features... So, why did you? There were plenty of other options with way better drivetrain and feature in 2020.
He’s not trying to hurt your feelings. He’s just saying the next vehicle will need to be massively upgraded. That chip on your shoulder is getting awfully heavy. Might want to address it.
I agree. The 4Runner is way, way behind other vehicles on tech, safety, and options. Toyota either needs to drop the 4Runner or upgrade it to a decent standard that compares to just the basic competitor’s vehicles. It will be very interesting to see what they do.
Ambrose67
