5th Gen Calipers
After you bleed your brakes you need to turn the vehicle off and do 40 full depress and release of the brake pedal. Then turn the vehicle on and give it 2 minutes you should notice the pedal being a lot firmer now. I would do it after you get the fronts done, I also used motive and this is the worst brake booster design I have seen so far. But I was able to get the chain through a small hole under the reservoir and make it work without any special adapters. I used close to 160 ounces for all of my calipers to get a good flush in :) Glad to hear all went well
Arthur4r thank you. Make any sense to do so now? I have already put 600 miles on them. Or are you saying, next time I work on the brakes? Thanks again.
If you finished with your fronts then do it now.
I just did this. And i didnt get any different results. Maybe am doing it wrong. I bleed my brakes awhile when i put on my ss lines.
This is a process that is recommended right after a brake flush on the vehicle. my pedal was "spongy" and once I done it I noticed right away my brake pedal being more firm and grabbing earlier if you will. It might vary from one person to another as brakes are very subjective but as I stated earlier I had great results and some other members also. The way I done it, turn the vehicle off. Press the brake pedal all the way in hold for a second and let go. Rinse and repeat 40 times it should take about 10 minutes. Make sure you
Depress the brake pedal fully to the floor it takes some strength but that's the only way it seems to work. I am currently mobile otherwise I would of find the exact Toyota document that list steps by step direction for a brake flush. If you search spongy brake pedal or brake flush you should be able to come across that thread.
Read my responses to this thread starting with reply #34:
http://www.toyota-4runner.org/4th-gen-t4rs/223054-5th-gen-caliper-install-gone-wrong-3.html
We got that OP fixed up with 40 sloooooow pumps with the key off of the brake pedal.
Good luck!
Oo ok. Thanks for the quick response. When i first stepped on it felt a click at first and then the pedal felt smooth anybody feel that ?
Looks like I'll be joining this club soon. After less than a year of swapping for brand new calipers, pads, and rotors (4th gen parts) they're already freezing up again.
I've checked the brakes twice over that time span, and the calipers were not fully retracted. I'll move the pistons back out, but over the span of a couple weeks my MPGs will drop from ~18mpg to ~15mpg for no reason. I've done just about every other MPG maintenance tip I've read on here (MAF, additives, filters, driving convervatively, etc) and it doesn't help.
This is the worst part about owning this vehicle.
Where did you you buy them? They might still be under warranty. I bought dualistic gold from autozone and when mine froze, I just swapped mine out. No charge.
Part numbers are here guys
From Rockauto
Calipers:
141.44587
141.44588
141.44287
141.44288
Rear Caliper Brake Flex Hose Stainless Steel Numbers:
950.44507
From All-Pro
Front Caliper Brake Flex Hose Stainless Steel Numbers:
5500FJT-AP-F x 2
Rear Axle Brake Flex Hose Stainless Steel Numbers:
5500FJ-AP x 2
Enjoy!
My front driver side rotors are cracked and I want to go ahead and replace both front rotors and calipers to the 5th gen upgrade. I want to order the centric painted calipers. does anyone have those part numbers for a 5th gen? I will be putting them on my 2005 4x4 sport V8. Thank you.
should be the numbers starting with 142. I don't believe they make a 142 series 5th gen front calipers yet
i don't know if this has been answered or not, is there a difference between 2WD and 4WD? I'm ready to also do the swap... and can i go for the 2015 model brakes?
Great call there. You might have saved me a lot of heartache. Got them from rockauto and looks like they have a 2 year / 24k warranty. I'll check it out.
would you mind posting the PNs for all six (6) of the SS lines. seems most kits only come with four (4) of them. i have been wanting to all 6 SS lines for a while.
fronts: centric 950.44007
rear caliper: centric 950.44507
rear axle: low range offroad FJC-SSBLR link
is what i used.
I'm ditching the 4th gen calipers for good. It's been a while since I've last gone through this thread, but can these be bought at local stores yet or is RockAuto the only option?
I'm going through warranty/returns with RockAuto right now for my old calipers and it's just a hassle.
I just bought a set from napa auto parts. It took a little digging for them to find a set, but they did.
Sent from my XT1585 using Tapatalk
Finished the swap tonight. Used centric rotors and calipers. Used the old pads, because really they're not old. Bled all 4 brakes with new speedbleeders (which are awesome). I can't say I've noticed any difference in stopping power, but having calipers that don't drag is a huge relief. Let's just hope it stays fixed this time.
That's awesome
Could you post part numbers or invoice/receipt?
Sent from my XT1575 using Tapatalk
AndiGarage
