5th Gen OEM Rock Rails
Factory Rock Rails
I found a 1 year old set locally. Installed on my 2017 SR5 and the fit is excellent.
As expected the powder coat was thin & rusty on the bracket weld areas. So I touched up with wire brush, a rust lock treatment then flat black Rustoleum paint brushed on the cleaned rust spots.
Installed myself with neighbors small floor jack.
Be sure to clean frame nut threads before starting install-major time saver! I ran bolt in then out on second side, wished I thought to do both sides before starting. The prefered wrench was a flex head box ratchet-a 1/4 drive socket & regular box wrench was not very useful.
Tube wall thickness about 1/8", frame bracket thickness about 1/4". I found plastic plugs for the tube ends. I am delighted with final result.
Let me know if you finally get a set!
REE
