5th Gen Sub enclosure wanted
Did someone confirm a harness that worked? and also what wires behind the head unit one is to tap into?
I see the wire colors but no correlation to the wire harness colors.
Looking to do a under the seat install. I saw pictures of he kicker box work... Are there any others and a specific part number that doesnt get to big?
Thanks in advance.
Thanks in advance.
This is what I used, works great and has RCA outputs, I did have to trim a plastic pin on the back of the radio to get it to fit
Toyota Lexus Scion Factory Radio Add A Subwoofer Amplifier Plug & Play Harness 86429002658 | eBay
The JL microsub 6.5 fits almost perfectly in the far right corner. Sounds great too if your not looking for rattle your neighbor bass. I found one at the crutchfield outlet for 168 to the door...can't beat the deal.
will this work with 3rd row. this is just what im looking for. that custom build on here would be better, but im pretty lazy.
Any 5th Gen owners near Connersville, IN 47331?
I contacted a a custom sub enclosure company subthump.com about possible 5th gen custom box for a shallow mount 10 inch sub. Hoping for a nice fit behind the cubbyhole in the rear or replacing it.
They replied:
"Hi,
Toyotas are not all that popular around here and I have never had access to one or know anybody who owns one. If we could get access, I would gladly do one to add to our catalog. Thx!
Steve
Owner: www.subthump.com"
They have a good selection of other makes and models and the FJ, and look to make some nice custom shapes.
Just putting it out there, hoping someone is close to Connersville, IN 47331.
5th gen Limited custom subwoofer
I was able to get a JL audio 12" Tw3 in a custom box in the stock location in my '12 limited with 3rd row. Had it in for about a year but just upgraded to a false floor. So if anyone is looking for a custom 12 box to fit in stock location...
I have this one. Only downside is that you cannot recline the rear seats anymore and it is pretty large
I just purchased a custom enclosure via ebay that fits a 10” shallow mount in the cargo cubby area. Should be here by next week. Ill measure it and order a woofer. Jl audio most likely.
is it from that m0nst3r seller? That guys an idiot fyi. had a horrible experience with him, hopefully he doesn't do the same with you.
What woofer are you using? How many watts are you feeding it? How does it sound?
I did a post here about my experience with it all: Full Audio Replacement - Focal/TacoTunes
But basically it's wired for 2ohms with their setup, the sub is an old Image Dynamics ID12D4 12" rated for 250W RMS and 450W peak
So it definitely has bass but it's not going to rattle your windows. I personally wanted a little more bass because I'm an idiot who likes having no hearing but I can certainly live with what this gives me. Can always upgrade to a different 12" later, though would probably need to add a mono amp
