5th Gen T4R Picture Gallery
I just mounted FN Countersteer X's 17inch, -10 offset on some KO2's 265/70/17 and it's definitely a lightweight and high performance upgrade. The FN wheels are amazing & the 17's are even lighter than the 18's. Loving my setup and the truck is not at all sluggish. The handling hasn't been affected at all, if anything it has improved!
Do these stick out from the fender any or right in line with it ?
Mammoth mountain got a good dump today! Shortly after this pic it was a white out blizzard for the rest of the day. image.jpg
Planning to get a lift? Just wondering your stance looks good. Im on the same boat as you i just installed 275 55 20 at tires and deciding if i should get a lift. What size rim and tire are you running?
I'm planning on getting a OME 3" lift. I currently have Level 8 Tracker 17" wheels wrapped in 265/70-17 General Grabber HTS, I had General Grabber AT2s before I moved from Arizona to North Carolina. I'll probably go with the AT2s again in 285s once is get the lift.
Re-visiting Monument Valley 12 years later
Last time I was there in 2003 driving a rental
erinobr2000
