5vzfe cam timing marks
W4R123
Hi,
I am assembling both my cylinder heads today by following the factory service manual. When it comes to aligning the timing dots on the back of the cam shafts, I notice the FSM says to align the 2 DOT marks on the RH head but on the LH head it says to align the 1 DOT marks...? I just want to confirm if that's actually the case before I bolt everything down. Does anyone have an answer to this? Thanks in advance!
You can align both 2 dots or 1 dot I never had an issue. I prefer the 2 dots on both sides. When you put the cams and pulleys then you can turn to TDC it won't harm anything.
seltzernator
